Disable "Choose Sound" button on audio widget
HI.
Sorry, this may sound stupid, but is there a way to disable the "Choose
Sound" button on the audio widget? Would just like to prevent data
collectors from accidentally choosing the wrong sound clip for a household
record. I believe using the Record Sound option automatically saves the
sound clip for the prompt.
Thanks.
Vinia
Hi Vinia,
This is an existing feature request at
https://code.google.com/p/opendatakit/issues/detail?id=892.
The core team doesn't have the cycles to do it right now so maybe a
community member can submit a patch. It's pretty straight forward.
On Tue, May 13, 2014 at 6:03 PM, Vinia Marciano viniamarciano@gmail.com wrote:
HI.
Sorry, this may sound stupid, but is there a way to disable the "Choose Sound" button on the audio widget? Would just like to prevent data collectors from accidentally choosing the wrong sound clip for a household record. I believe using the Record Sound option automatically saves the sound clip for the prompt.
Thanks.
Vinia
Thanks, Yaw.
··· On Wed, May 14, 2014 at 9:14 AM, Yaw Anokwa wrote:
Hi Vinia,
HI.
Thanks.
Vinia
