Hi there,
I would like to know if is it possible to insert a label question into a note.
The fact is : I have a survey which try to evaluate levels on MDC skills.
Interviewees answer different skills such as "Clean data before analysis" and they evaluate themselves by ticking a level on the likert scale.
Regarding to the answer I would like to display some of them skills into a note : " You mention having difficulties for the following activity(ies): ...".
But I did not manage to fix it myself.
By example :
The intervewee answers to have "significantly" difficulties to "1.1 Find external / secondary data relevant to your activities"
So my survey will display:
"You mention having difficulties for the following activity(ies): 1.1 Find external / secondary data relevant to your activities"
I am using EXCEL 2013, KOBO Humanitarian response & ODK Collect v1.22.4.
First, I define other variable by re-write label question :
calculate > dif1 **> calculation : ** if(selected(${dif_1},'niv_1') or selected(${dif_1},'niv_2') or selected(${dif_1},'niv_3'),'1.1. Trouver des données externes / secondaires pertinentes pour vos activités','').
But I can not keep that as I have different language.
Then, I delete text into this command, to keep the number. But it's clearer with text.
After, I deal with several commands to fix it (jr choice, $(answer)). Also try to write my XLSForm in another way.
I join my XLS form to show the issue.
- From row 24 to 53 it's what I try to display my label question.
- My problem will be for what it's display with row 54 : "You mention having difficulties for the following activity(ies): ${dif1} ${dif2} ${dif3} ${dif4} ${dif5} ${dif6} ${dif7} ${dif8} ${dif9} ${dif10} ${dif11} ${dif12} ${dif13} ${dif14} ${dif15} . "
I hope it's understandable,
If someone have an idea, will be happy to hear about it !
Thank you,
Chloé
Qlabel.xlsx (111.0 KB)
