Please I need an ugent assistance. I intended to host odk central on Digitaocean with my Domain in Squarespace, I did the console configuration for Droplet in Digitalocean successfully but my domain is not accessble. Please kindly assist
Hello @ict2021
Did you successfully install ODK Central on Digital Ocean following this guide https://docs.getodk.org/central-install-digital-ocean/ ?
Also, can you please specify the configuration you made on Digital Ocean side?
Looking forward to hearing from you
Regards
Thank you sir, for your help. I have successfully install the server but I am having two critical issues:
- my doman on the ODK Central was working one time but it started showing "refused to connect"
- The login credentials I created during the installation of my server are not working on the ODK Central login page.
please kindly assist on how to fix these issue permanently, thank you.
@ict2021,
Thank you for replying back.
1)
Did your credentials work before the "Refused to connect" issue?
2)
a-did you provide the three DigitalOcean's name servers on the side of your domain's registrar?
b- did you create an A-record for your droplet on the side of your domain's registrar?
Looking forward to your reply.
Regards
Thank you sir,
I didn't create an A-record on my droplet on the side of my domain's registrar.
Honestly, I will be appreciated if you can guide me on that. And finally I notice that my console is not loading too.
Thank you
@ict2021 ,
- Provide DigitalOcean's nameservers on your domain's registrar side
On the website of your registrar, navigate to the "Management section of your domain"
Open the "Nameservers" subsection and fill out the dedicated fields with the following three DO's nameservers:
ns1.digitalocean.com
ns2.digitalocean.com
ns3.digitalocean.com - Create an A-record
In the "Manage domain section",
Go to the "Manage DNS host records" subsection and create a new A record, where value should be your droplet's IP address - Create an A record on DO's side
You should also create an A record on the side of DO after adding your domain to your droplet
Hope these help
Great!
I hope you didn't forget to click the Update NAMESERVERS button ?!
What about the A record creations?
Ok, I didn't click Sir, thank you for the reminder
