Does Aggregate combine survey results when the questions are identical?
Hi All,
My org has an Aggregate v1.4.5 deployment that contains two surveys with the same question names, but differing form ids and instance root element names. When trying to download the data, we found that the exports for both surveys were the same. When viewing the responses in the web-view, the data also appears to be identical. We think the responses are being combined because the questions are the same, but I would like to confirm that this could be the case.
-Nathan Breit
If the form ids are different, the forms will be stored in separate tables
and not combined.
If the form ids are the same and they have different form versions, then
they will be combined and you can see the version of the form used in the
submission in the form version metadata column.
ยทยทยท On Tue, Jun 28, 2016 at 12:32 PM, wrote:
Hi All,
could be the case.
-Nathan Breit
