Doesn't work filter action for next question answer
There has been a problem trying to replace ${desig_pre} with the XPath to the survey element named 'desig_pre'. There is no survey element with this name.
Could you help me
Doesn't work filer action on next answer.
ttttt.xlsx (66.2 KB)
Hi @khantkah_kah
Your survey element name is designation and not desig_pre, replacing the survey name fixes the issue. See attached file.
ttttt.xlsx (65.9 KB)
