Hello,
I am trying to draw a random number between 1 and 5 (inclusive). The point would be to make certain questions relevant based on this draw. Any help would be greatly appreciated.
TK
Hello,
TK
You can do *random()5 in calculation of field: calculate
random() output random number in [0,1]. XFORM does the rounding to integer.
I think you are close, Hung.
The traditional way of doing this is: floor(random() * (max - min + 1)) + min.
JavaROSA doesn't have floor, so you can do it like: int(random() *
Caveat is this only works if you are expecting positive numbers from
random() * (max - min + 1).
On Fri, Oct 2, 2015 at 5:25 AM, Hung Pham hpham2709@gmail.com wrote:
You can do random()*5 in calculation of field: calculate
On Wednesday, 30 September 2015 20:46:18 UTC+1, Tanu Kumar wrote:
Hello,
would be greatly appreciated.Thanks,
TK
Nice. I learn something new today.
Thanks Yaw.
Should start looking into JavaROSA source code soon.
Hung
Hung,
One easy contribution is for you to add floor() and ceil() to the
JavaROSA code. Give it a try!
Thanks Yaw.
Hung
Yaw,
I will give it a try and report back for result.
Hung.
And whenever you use random(), you should wrap it with once()
Yaw,
Hung.
Search the list for once( or random( for earlier posts
On Fri, Oct 2, 2015 at 2:17 AM, Hung Pham hpham2709@gmail.com wrote:
Yaw,
Hung.
