I have a user using a Droid 3 by Motorola It is running Android
2.3.4. They are able to install ODK Collect 1.1.5, but when they go
to collect a photo it crashes. If they skip the photo no problem. We
have tried other camera apps and same issue. Is there anyone using a
Droid 3 with ODK?
> Droid 3 with ODK?
> Thanks
I going to get my hands on this persons phone soon and will be able to
get a stack trace
Camera Apps Tried:
Sleek Camera
Retro Camera
Pro Paint Camera
The user tried all of these...he is not the most tech guy around...so
I am not sure how well the installs went with these. I hope to get my
hands on his phone this week and will keep you posted.
On Oct 25, 9:22 am, Yaw Anokwa wrote:
> andrew,
> my guess is that the camera apps you are using doesn't support the
> default android command to take pictures. what other camera apps have
> you tried?
> also, if you can, please get a stack trace (seehttp://opendatakit.org/help/faqfor instructions) and file a bug athttp://code.google.com/p/opendatakit/issues/listso we make sure to
> prevent this bug in 1.1.7.
> yaw
> > Droid 3 with ODK?
> > Thanks
