Dynamic choices from roster in same form
I am newbie to ODK and doing a project with it, I need to know how I can use previously entered vales in a roster for example Students name in "student_repeat" group in outside for new questions choice set, for example "Select the best student for swimming?" in this case choices must come from previously entered names of the students .
so hope you got the point.
Hey @chandi ,
Please check this. This can help you to make a login.
in this section, you need to make select multiple type question and then save all the response which has been entered by the user and show them in the next question.
Are you clear? If you can share your tool then you will get faster response.
@iamnarendrasingh
It sounds like you may be looking for building a select one from a repeat.
Thanks lot I got it thanks for your time.
