We are trying to get elephant-farmer conflict incident information in the field in a remote part of central Tanzania using ODK. The forms work great and the village data collectors picked it up easily as they are all cell-phone savvy (and the use of the software and tablets keeps interest high which is very important - paper and pencil data collection is boring...). BUT.....when we use the GPS location finder question on our form we cannot get a location within 2 km accuracy on our Tecno P9 tablets (we turned on the GPS enabler, but am not sure if these tablets have the capacity to get satellite-based GPS without networks or internt). Please, if you have any insights into any of the questions below it would be greatly appreciated....
We have Tecno P9 tablets, but despite our best efforts (turning GPS on) it appears they cannot get good GPS locations without connecting to a phone network or the internet (we have neither).
We are looking at smartphones that have independent (not assisted GPS) GPS function, but we cannot find out if they get GPS locations based on satellites only without pinging on a cell tower even if the SIM card is removed. If they can and they can get accurate (>50m) locations we will ditch the tablets and get smartphones (both are hard to read in the sun, however).
Do we have to get 'unlocked' tablets or smartphones (whatever that means), do we have to download maps from one of the many apps or google map options in order for the satellite based GPS capacity to work well (not sure why this would work any different for simple triangulation of satellites).
I need to know specifically what smartphones we should use with ODK and if we need to ensure they are 'unlocked', confirm they have unassisted GPS capacity (none of the specs ever tell this), and whether we need to download Tanzania maps.
If you can help with any of this, we greatly appreciate it. Asante sana!
2 km accuracy sounds like something is horribly wrong with those
tablets (or they don't have an actual GPS chip). Most Android devices
with GPS on the market today can get 5 m accuracy and don't need to
connect to the cell or WiFi network. They don't need to be unlocked
and you don't need to download any maps.
If you are looking for a recommended tablet, I like the Nexus 7. The
2012 version is great if you don't need a camera. If you do, the 2013
is recommended because it has a rear facing camera. If you want a
phone, I like the Nexus 4. The Nexus 5 is good too.
appreciated....
however).
Tanzania maps.
Thank you all for your replies. They are all very helpful. It seems that
the problem is the weak or lousy recievers in the Tecno P9 when used in
remote areas. They work fine in towns with networks and fortunately we have
another project in Zanzibar where we can use them. Samsung smartphones are
VERY expensive here in East Africa, although they do work well I think, so
we are looking at Huawei phones. Any other recommendations are most
appreciated. The elephants thank you...
Another issue overall is that the screens are very hard to read in the
field on both tablets and smartphones, especially when it is sunny, and we
actually take readings in fields (crops) in the field where elephants have
snacked on maize.
On Friday, April 25, 2014 5:31:42 PM UTC+3, Conservation Earth wrote:
> Jambo ODK Gurus,
> however).
> Dave
> David Olson, PhD
> Conservation Earth Consulting
> www.conservationearthconsulting.com
> conserva...@live.com
Ian, Can you clarify if you were able to get readings in areas with no cell
towers or internet? Several smartphone makers say that their products do
not have the capacity and we are wondering if the phones are pinging off of
cell towers even when the network and wifi are turned off? On the ODK form,
we also cannot set a location if the GPS page is still processing, so it
will be difficult to know if it is actually taking a location and at what
accuracy. Thank you again for your help.
> Jambo ODK Gurus,
> however).
> Dave
> David Olson, PhD
responses, I still am not certain if the smartphones are using cell towers
to ping off of to find their location even if the SIM card is removed and
internet is off. I talked to SAMSUNG tech help and they said none of the
smartphones can get GPS using only satellites, all of their phones use
A-GPS. Some folks mentioned that they use smartphones and tecno tablets in
remote areas, but it is still unclear if their phones are using cell
towers
to triangulate or using an internal chip to read satellite data only. Do
you
> have any suggestions on how we can get a definitive answer?
Jambo ODK Gurus,
however).
These cheap Tecno devices seem to be really catching on in Africa.
I just did a project in Ethiopia using P5, D1 and Q1 phones and in general
the cheaper the model the worse the GPS (the p range are actually the
best). Whatever you choose from Tecno they will take an extremely long
time to get a GPS reading especially if the network is poor or non existent
The Tecnos mostly run 4.0 so you should be able to select to use GPS
satellites in settings
Tap Menu
Tap Settings
Tap Location & security
Tap to Use GPS Satellites
You should also be aware that for a long time we thought that GPS was not
working when looking at the collected data map on formhub. This was because
it seems formhub maps on the first GPS question it finds so if this
question is contextual and other repeats or groups also contain GPS
questions the subsequent GPS questions will not show on the map (their
locations will however be in the Excel export).
Hope this helps
On Fri, Apr 25, 2014 at 4:29 PM, Yaw Anokwa wrote:
David,
great
form
Please, if
appreciated....
it
GPS
however).
means),
options
if
download
Tanzania maps.
I agree with yaw the nexus are the best value for money but hard to source
in Africa.
Stick with samsung. The samsung trend in particular is extremely impressive
for the money.
On Friday, April 25, 2014, Yaw Anokwa wrote:
David,
great
form
Please, if
appreciated....
it
GPS
however).
means),
options
if
download
Tanzania maps.
email to opendatakit+unsubscribe@googlegroups.com <javascript:;>.
Thank you all for your replies. They are all very helpful. It seems that the problem is the weak or lousy recievers in the Tecno P9 when used in remote areas. They work fine in towns with networks and fortunately we have another project in Zanzibar where we can use them. Samsung smartphones are VERY expensive here in East Africa, although they do work well I think, so we are looking at Huawei phones. Any other recommendations are most appreciated. The elephants thank you...
Another issue overall is that the screens are very hard to read in the field on both tablets and smartphones, especially when it is sunny, and we actually take readings in fields (crops) in the field where elephants have snacked on maize.
Jambo ODK Gurus,
Hi Dave
We have project running in East Africa as well and use Samsung GS5301 phones.
They are very efficient and very cost effective.
They cost about USD130 and have a lifespan of 2 years at least and we use them without simcards so you don't need to worry about that either.
Go outside and make sure you have a clear view of the sky and
launch GPS Status.
If you have true GPS and you have a clear view of the sky, you should
get a lock in <10 minutes and it should be about 5 meter accuracy.
On Mon, Apr 28, 2014 at 7:29 AM, dave olson veikau1@gmail.com wrote:
Thank you for all of your help. Given the various
towers
you
Jambo ODK Gurus,
appreciated....
however).
Tanzania maps.
the cheaper the model the worse the GPS (the p range are actually the best).
Whatever you choose from Tecno they will take an extremely long time to
Tap Menu
Tap Settings
it seems formhub maps on the first GPS question it finds so if this question
is contextual and other repeats or groups also contain GPS questions the
subsequent GPS questions will not show on the map (their locations will
the
great
form
(we
Please, if
greatly
appreciated....
it
GPS
however).
means),
options
if
download
Tanzania maps.
general
best).
Tap Menu
Tap Settings
because
question
the
great
interest
our
form
(we
Please, if
greatly
appreciated....
on)
it
phone
GPS
is
will
sun,
however).
means),
options
Thank you for the advice on the Samsung. They are quite expensive in Nairobi and Dar so we opted for the Tecno tablet, but you get what you pay for. Are you working in a remote area without cell service or towers? If not, the phones might still be pinging off of towers to get locations even without SIM cards. I am not sure if this is the case, but need to make sure before we buy 5 smartphones. Thank you very much.
> Date: Sat, 26 Apr 2014 08:55:05 -0700
> From: leah.ndikuwera@evidenceaction.org
> To: opendatakit@googlegroups.com
> CC: conservationearth@live.com
> Subject: Re: Elephants! ODK Help!
> > Jambo ODK Gurus,
> > Dave
> > David Olson, PhD
> Hi Dave
The Tecno tablets worked in the field after we tried them again, I do not
know why they worked the second time in the field, but someone had
suggested they take a really long time to register GPS at first and we also
downloaded some GPS app and now they work with good accuracy and without
internet or cell network. The first time I had done everything that I
thought was correct, turned on all the GPS and other location settings, but
they did not work. The second time to the field they did. Using the larger
tablets facilitates interest on the part of the data collectors and farmers
we are working with in the field, more so than smartphones (we bought some
and they work too and will use them for another project) or paper and
pencil.
A few reminders, make sure to check the forms as finalized before sending.
Also, four of our questions do not show as marked on the tablets, even in
the editing phase and after new information is put in on the tablet, so we
sent them to aggregate anyway and the data that was entered in the field
showed up - this is a bug in the system I guess, but we will proceed as the
data is being collected and received.
And when the data collectors added their code to the form name at the end
it does not show in aggregate so we had to add the form codes to the first
question that says the data collectors name, another thing that could be
fixed in future versions.
Thank you again for all your help.
David
On Monday, April 28, 2014 5:41:25 PM UTC+3, Yaw Anokwa wrote:
> Dave,
> The easiest way to answer your question is to test the device under
> the following conditions.
> 1. Remove the SIM. You can now be sure you aren't using cell localization.
> 2. Turn off WiFi. You can now be sure you aren't using WiFi localization.
> 3. Install GPS Status
> (https://play.google.com/store/apps/details?id=com.eclipsim.gpsstatus2)
> 4. Go outside and make sure you have a clear view of the sky and
> launch GPS Status.
> Yaw
> towers
> and
> the
> in
> >> towers
> Do
> >> you
> >> Jambo ODK Gurus,
> the
> great
> interest
> form
> (we
> Please, if
> greatly
> >> appreciated....
> it
> phone
> GPS
> sun,
> >> however).
> means),
> options
> why
> if
> download
> >> Tanzania maps.
> sana!
> >> Dave
> >> David Olson, PhD
> Groups
> > "ODK Community" group.
> an
Another reason to "hate" SS is that they're shipped with lots of junky apps
which you can not uninstall.
On Saturday, April 26, 2014 11:36:45 AM UTC+7, Matt Berg wrote:
> Yaw thanks for flagging that didn't realize that.
> On Saturday, April 26, 2014, Yaw Anokwa <yan...@nafundi.com > wrote:
>> Matt,
>> Caveat about Samsung devices. They don't always implement
>> getExternalStorageDirectory() and so some of them have weird /sdcard
>> behavior.
>> See thread at
>> https://groups.google.com/d/msg/opendatakit/y0gnGTULdoE/nocV3a8lYnkJ
>> Yaw
>> On Fri, Apr 25, 2014 at 1:32 PM, Ian Lawrence wrote:
>> > Hi
>> general
>> best).
>> > Whatever you choose from Tecno they will take an *extremely* long time
>> to
>> > Tap Menu
>> > Tap Settings
>> not
>> because
>> question
>> > subsequent GPS questions *will not* show on the map (their locations
>> will
>> > Hope this helps
>> >> David,
>> >> Yaw
>> >> On Fri, Apr 25, 2014 at 7:31 AM, Conservation Earth wrote:
>> >> > Jambo ODK Gurus,
>> >> > the
>> >> > great
>> interest
>> our
>> >> > form
>> >> > (we
>> >> > Please, if
>> >> > greatly
>> >> > appreciated....
>> on)
>> >> > it
>> phone
>> GPS)
>> >> > GPS
>> is
>> will
>> sun,
>> >> > however).
>> >> > means),
>> >> > options
Glad things are working Dave. What you describe below may or may not
be a bug. Best way to figure that out is to attach your XLS form to a
bug report at https://code.google.com/p/opendatakit/issues/list.
Most of the specifications I saw online re that particular tablet state
that it only supports A-GPS That means, you can only use your location
with a data connection, and a phone signal from your network.
apps which you can not uninstall.
general
best).
to
Tap Menu
Tap Settings
not
because
question
will
the
great
interest
our
form
(we
Please, if
greatly
appreciated....
on)
it
phone
GPS)
GPS
is
will
email to opendatakit+unsubscribe@googlegroups.com<javascript:_e(%7B%7D,'cvml','opendatakit%2Bunsubscribe@googlegroups.com');>
Nik
Need help customizing Survey Instruments/Tools/Forms for ODK Collect? Drop
me an email.
Thank you all again for your comments. This has been a tough issue to get
certainty on. Some folks are having good luck in the field without networks
with the Samsung smartphones while others are cautious about them as the
specs say A-GPS only. We are also looking at Huawei which are very common
here. The true test is when we get to the field and try to use them (24 hr
bus ride....), so we are trying to pin things down as much as we can here
in Nairobi first. My big question is if the smartphones are still pinging
off of cell towers even if the SIM card is removed and the internet
switched off, or are they getting location solely from satellite? I read
they have to have a special chip to do this (NVASS?) but that all USA
phones are required to carry these now. Thank you again for everyone's
assistance.
On Monday, April 28, 2014 6:52:54 AM UTC+3, ニコノコ wrote:
> David,
> that it only supports *A-GPS* That means, you can only use your location
>>> On Saturday, April 26, 2014, Yaw Anokwa wrote:
>>> Matt,
>>> behavior.
>>> See thread at https://groups.google.com/d/msg/opendatakit/y0gnGTULdoE/
>>> nocV3a8lYnkJ
>>> Yaw
>>> > Hi
>>> general
>>> best).
>>> to
>>> > Tap Menu
>>> > Tap Settings
>>> not
>>> because
>>> question
>>> the
>>> will
>>> > Hope this helps
>>> >> David,
>>> >> Yaw
>>> >> > Jambo ODK Gurus,
>>> in
>>> >> > the
>>> >> > great
>>> interest
>>> our
>>> >> > form
>>> tablets
>>> >> > (we
>>> >> > Please, if
>>> >> > greatly
>>> >> > appreciated....
>>> on)
>>> >> > it
>>> phone
>>> GPS)
>>> >> > GPS
>>> card is
>>> will
>> email to opendatakit+unsubscribe@googlegroups.com.
> Nik
> me an email.
