I am using ODK central, hosting by my own server. I have the form that contained 2 languages and has multiple pre-defined cascading loops and dynamic selection.
The problem I have is where I have a question asking data collector to select_one choice and the next questions will ask the same but removing one of the chocies that selected.
for example:
Please select_one
a. A (A is selected)
b. B
c. C
Please select_one
b. B
c. C
I can use the form in Collect without any problem and the loops and sorting choices are also working fine. Also, I have look at submitted data in CSV file and it is completed.
However, I want to do some permanent editing so I open the enketo editing but the submitted data has disappear, on the question the choice showed : none selected and cant edit at all.
I can share the form if that is helpful-
The form has dynamic selection
Please select_one
a. A
b. B
c. C
if answer A
Please select_one
a. A1
b. A2
c. A3
and the loops go on for B and C...
I have rechecked the form in collect and checkef the data in csv exported files - they all works fine- just that cant edit on Enketo. and I have try to find the article on the forum but cant find any
4. Upload any test forms or screenshots below.
FORM_that have issue_enketo.xlsx (116.8 KB)
