Has Enketo changed so it automatically numbers survey items?
It used to display the numbers we manually assigned survey items. Today it is assigning most items "1." with some exceptions of items that open when relevant. thank you
Not that I'm aware of, but I am also not sure what you mean. Are you
experiencing an issue with the previews on http://opendatakit.org/xiframe?
Can you send a simplified test form that demonstrates the issue?
Martijn
On Monday, October 5, 2015 at 11:18:54 AM UTC-6, jml...@yahoo.com wrote: > > Has Enketo changed so it automatically numbers survey items? > It used to display the numbers we manually assigned survey items. Today it > is assigning most items "1." with some exceptions of items that open when > relevant. thank youThanks for your response outside this forum. It's a regression (bug) caused
by adding support for more advanced markdown syntax and across all
questions and labels (still to be formally announced and documented after
ODK Collect has added this too) . Glad you found this. It will be fixed
shortly.
In the mean time if you leave out the dot after the number, it won't be
picked up as an 'ordered list' so it won't be renumbered.
On Tuesday, October 6, 2015 at 1:33:39 PM UTC-6, Martijn van de Rijdt wrote: > > Hi, > > Not that I'm aware of, but I am also not sure what you mean. Are you > experiencing an issue with the previews on http://opendatakit.org/xiframe? > Can you send a simplified test form that demonstrates the issue? > > Thanks, > Martijn > > On Monday, October 5, 2015 at 11:18:54 AM UTC-6, jml...@yahoo.com wrote: >> >> Has Enketo changed so it automatically numbers survey items? >> It used to display the numbers we manually assigned survey items. Today >> it is assigning most items "1." with some exceptions of items that open >> when relevant. thank you > >Hi Jeanette,
This should be fixed now. Thanks again!
(test form
https://odk.enke.to/preview?form=http://23.21.114.69/xlsform/downloads/tmprpSecx/markdown.xml
- temporary link)
Cheers,
Martijn
