I am using a numeric keypad to enter data in inclement weather. We are attempting to touch the tablet screen as little as possible. I would like to enter the sex of a species as either 1,2, or 3 in an integer type question and have the output after data download appear as a character either M,F, or U.
Using xlsforms to design the form and kobotoolbox to deploy the html form.
Have tried if then statements in the calculation field but can't seem to get the form to function with these.
For example: if(${Sex}=1,${Sex}=M) or if((${Sex}='1','M',if(${Sex}='2','F',if${Sex}='3','U')
Using a numeric keypad in this context makes a lot of sense. This is a requirement that others sometimes have -- it would be helpful if you could share the make and model of the device you're using.
To do what you're trying to, you'll need two separate fields. It sounds like you already have the integer question set up as you want. I'll assume it has name sex_input below but you can name it whatever you want. The second will be a calculate and could be named sex, for example. Its calculation will look something like
It looks like your second attempt was close but you had parentheses in the wrong place. Note that if your first question has a constraint to only allow values 1-3, you don't need to explicitly check for the 3 case and can output 'U' as long as neither 1 or 2 was matched.
This is great @LN, thank you for your input.
FYI I am using Panasonic Toughpad FZ-M1 tablets. They are quite rugged but seem to be prohibitavely expensive. I would not recommend them and would use a less expensive tablet with waterproof case in the future. Also, they do not run Android which necessitates the use of HTML form instead of using ODK collect.
