I install tokyocabinet, tokyotyrant in my local system and manage to run
odk build , when i start the server it works fine, and i see the odk build
form in localhost in 127.0.0.1:9393/ but when i started on the next day,
it says the following error when i run "bundle exec shotgun config.ru"
root@ubuntu:/home/naveen/Desktop/odkbuild-master# bundle exec shotgun
/usr/lib/ruby/vendor_ruby/bundler/runtime.rb:136: warning: Insecure world
writable dir /usr/local/sbin in PATH, mode 040777
== Shotgun/WEBrick on http://127.0.0.1:9393/
[2013-07-08 10:08:54] INFO WEBrick 1.3.1
[2013-07-08 10:08:54] INFO ruby 1.8.7 (2011-06-30) [x86_64-linux]
[2013-07-08 10:08:54] WARN TCPServer Error: Address already in use -
bind(2)
/usr/lib/ruby/1.8/webrick/utils.rb:73:in initialize': Address already in use - bind(2) (Errno::EADDRINUSE) from /usr/lib/ruby/1.8/webrick/utils.rb:73:in
new'
from /usr/lib/ruby/1.8/webrick/utils.rb:73:in create_listeners' from /usr/lib/ruby/1.8/webrick/utils.rb:70:in
each'
from /usr/lib/ruby/1.8/webrick/utils.rb:70:in create_listeners' from /usr/lib/ruby/1.8/webrick/server.rb:75:in
listen'
from /usr/lib/ruby/1.8/webrick/server.rb:63:in initialize' from /usr/lib/ruby/1.8/webrick/httpserver.rb:24:in
initialize'
from
/var/lib/gems/1.8/gems/rack-1.3.4/lib/rack/handler/webrick.rb:10:in new' from /var/lib/gems/1.8/gems/rack-1.3.4/lib/rack/handler/webrick.rb:10:in
run'
from /var/lib/gems/1.8/gems/shotgun-0.9/bin/shotgun:156
from /var/lib/gems/1.8/bin/shotgun:19:in `load'
Could anyone help to solve this error.
Naveen
