Hello
I am using ODK Aggregate 1.4.7 on Google Cloud Platform
I have enabled the following APIs (I didn't find the one that corresponds
to Google Map Engine on the new UI of the Google Cloud Platform):
API
Drive API
https://console.cloud.google.com/apis/api/drive/overview?project=mw-forms
https://console.cloud.google.com/apis/api/drive/drive_sdk?project=mw-forms
Fusion Tables API
https://console.cloud.google.com/apis/api/fusiontables/overview?project=mw-forms
Google Maps JavaScript API
https://console.cloud.google.com/apis/api/maps_backend/overview?project=mw-forms
Then, through the API Manager, I first create a Service Account using the
option Permission > Service Accounts > Create Service Account. I gave it a
name that also works as the prefix of the Service Account ID, and by
selecting the option "Furnish a new private key" I could also download the
public / private key pair using the P12 format. After that, I got an email
address with the form @.iam.gserviceaccount.com and
a its numeric Key ID.
Finally by selecting API Manager > Credentials > Create credentials > API
Key, I could generate the Browser API Key.
To enter the credentials into ODK Aggregate I:
- Used the Browser API Key as the Simple API Key
- Used the downloaded public / private P12 key file as the Private key file
- Used the numeric Key ID as the Client ID
- Used the @.iam.gserviceaccount.com as the Email
address
As the new UI of Google Cloud Platform differs from whats is mentioned in
the instructions
(https://opendatakit.org/use/aggregate/oauth2-service-account/), I am
afraid I am doing something wrong as I am getting the following error
message:
Error: RequestFailureException
(com.google.api.client.googleapis.json.GoogleJsonResponseException: 400
"code" : 400,
"errors" : [ {
"domain" : "global",
"message" : "Bad Request. User message: "Sorry, cannot transfer
ownership to help@mobywise.com. Ownership can only be transferred to
another user in the same domain as the current owner."",
"reason" : "invalidSharingRequest"
Please, any guidance on the issue is very much appreciated.
Cordial best
Daniel
Thanks for the note on the documentation being out-of-date. I'll be
sweeping the documentation on AppEngine / Google configuration soon to
update it to reflect their current UI.
From the error message, this is a limitation of the ownership-transfer that
Google allows. You probably need to specify a @gmail.com account when
publishing to Sheets or Fusion Tables.
i.e., it may not work for Google Apps Domains.
or perhaps you can log out of all your google accounts, log into your
Google Apps Domain account, then create the service keys and service
account under that apps domain account?
This was broken functionality on the Google's Apps platform 4+ years ago.
Not sure what the current status of this is (it is not something that ODK
can do anything about).
On Fri, Mar 18, 2016 at 3:26 AM, Mobywise Help help@mobywise.com wrote:
Hello
API
Drive API
Fusion Tables API
and a its numeric Key ID.
file
address
the instructions (
message:
"code" : 400,
"errors" : [ {
Cordial best
Daniel
Hi Mitch,
I need heal. I have installed ODK Aggregate with Tomcat 6. When I try to upload a form i have his error:
Problem with JavaRosa Parsing Form: org.opendatakit.aggregate.exception.ODKIncompleteSubmissionData: org.javarosa.xform.parse.XFormParseException: XML Syntax Error at Line: 1, Column: 667!
La requête envoyée par le client était syntaxiquement incorrecte.
please help me to understand my problem
Did you find a solution to this we can publish to gmail accounts but not
google apps or google apps for education accounts either.
On Friday, March 18, 2016 at 8:26:20 PM UTC+10, Mobywise Help wrote:
> Hello
> API
> Drive API
> Fusion Tables API
> 1) Used the Browser API Key as the Simple API Key
> 2) Used the downloaded public / private P12 key file as the Private key
> file
> 3) Used the numeric Key ID as the Client ID
> 4) Used the @.iam.gserviceaccount.com as the Email
> address
> the instructions (
> message:
> "code" : 400,
> "errors" : [ {
> "message" : "Bad Request. User message: \"Sorry, cannot transfer
> ownership to he...@mobywise.com . Ownership can only be
> transferred to another user in the same domain as the current owner.\"",
> Cordial best
> Daniel
Do not reply to an existing message thread and ask an entirely different
question.
Always create a new e-mail thread.
If you used ODK Build, it is likely that the form is missing some critical
entries, like the set of choices in a selection list.
Download ODK Validate and see what errors it reports for the form.
On Wed, Mar 30, 2016 at 5:24 AM, wrote:
Hi Mitch,
Column: 667!
Haven't tried it lately.
At a minimum, you would need to use your Apps Domain account when creating
your AppEngine project.
It is unclear whether the service account that we use will be constructed
such that it is associated with the apps domain, or if it remains a
gmail-linked service account (in which case it would fail to work).
If this does work, it is likely that you would then no longer be able to
share the publishers with ordinary gmail accounts (it would probably be an
either/or behavior).
Hello
API
Drive API
Fusion Tables API
file
Email address
the instructions (
message:
"code" : 400,
"errors" : [ {
ownership to he...@mobywise.com. Ownership can only be transferred to
Cordial best
Daniel
I'm currently having the same trouble and have created the service keys and
and service account under the google apps domain account. No luck yet.
Mobywise, did you ever find a solution?
I'll repost if I come up with anything.
Oliver
> that Google allows. You probably need to specify a @gmail.com account
> when publishing to Sheets or Fusion Tables.
> On Fri, Mar 18, 2016 at 3:26 AM, Mobywise Help <he...@mobywise.com > wrote:
>> Hello
>> API
>> Drive API
>> Fusion Tables API
>> file
>> Email address
>> the instructions (
>> message:
>> "code" : 400,
>> "errors" : [ {
>> Cordial best
>> Daniel
>> "ODK Community" group.
> Mitch Sundt
> Software Engineer
> mitche...@gmail.com
Oliver,
Are you still having this problem? What have you tried so far?
On Mon, Mar 13, 2017 at 2:09 PM, Oliver Burdekin <oliverburdekin@burdgis.com wrote:
and and service account under the google apps domain account. No luck yet.
Oliver
On Fri, Mar 18, 2016 at 3:26 AM, Mobywise Help he...@mobywise.com wrote:
Hello
corresponds to Google Map Engine on the new UI of the Google Cloud
Platform):
API
Drive API
Fusion Tables API
the option Permission > Service Accounts > Create Service Account. I gave
it a name that also works as the prefix of the Service Account ID, and by
API Key, I could generate the Browser API Key.
file
Email address
in the instructions (https://opendatakit.org/use/a
ggregate/oauth2-service-account/), I am afraid I am doing something
wrong as I am getting the following error message:
Error: RequestFailureException (com.google.api.client.googlea
"code" : 400,
"errors" : [ {
Cordial best
Daniel
Groups "ODK Community" group.
mitche...@gmail.com
Hi yaw. Yes it's still persisting. I've written a full account of what I've
tried on another thread so will dig that out and post the link here when I
get back to my laptop.
Mitch says it's a problem on Googles side that he's come across before 4+
years ago that hasn't changed.
Ultimately I think it's because I have a Google app domain (
email@mydomain.com) rather than a straight Gmail.com account.
Cheers,
Oliver
Sent from my mobile device. Please forgive short replies and / or typos.
On 19 Mar 2017 16:19, "Yaw Anokwa" yanokwa@nafundi.com wrote:
Oliver,
On Mon, Mar 13, 2017 at 2:09 PM, Oliver Burdekin < oliverburdekin@burdgis.com> wrote:
Oliver
ODK can do anything about).
Hello
Platform):
API
Drive API
Fusion Tables API
file
Email address
"code" : 400,
"errors" : [ {
Cordial best
Daniel
mitche...@gmail.com
To unsubscribe from this topic, visit https://groups.google.com/d/
topic/opendatakit/BhMDOQb04Uk/unsubscribe.
Hi Oliver,
No need to send out a link. I now remember the thread and yes, I agree it's
a Google Apps issue.
On Sun, Mar 19, 2017 at 1:37 PM, Oliver Burdekin <oliverburdekin@burdgis.com wrote:
I've tried on another thread so will dig that out and post the link here
when I get back to my laptop.
Cheers,
Oliver
Oliver,
Oliver
ago.
Hello
Platform):
API
Drive API
Fusion Tables API
key file
Email address
"code" : 400,
"errors" : [ {
Cordial best
Daniel
mitche...@gmail.com
To unsubscribe from this topic, visit https://groups.google.com/d/to
Okay thanks for looking into it Yaw. I'm more familiar with AWS so I think
I'll set up briefcase on there to export to S3 and go from there. The
project is running already so I'm loathe to change the aggregate set up now.
On 19 Mar 2017 17:50, "Yaw Anokwa" yanokwa@nafundi.com wrote:
Hi Oliver,
it's a Google Apps issue.
On Sun, Mar 19, 2017 at 1:37 PM, Oliver Burdekin < oliverburdekin@burdgis.com> wrote:
Cheers,
Oliver
Oliver,
Oliver
ago.
Hello
Platform):
API
Drive API
Fusion Tables API
serviceaccount.com and a its numeric Key ID.
key file
Email address
mentioned in the instructions (https://opendatakit.org/use/a
"code" : 400,
"errors" : [ {
to another user in the same domain as the current owner."",
Cordial best
Daniel
send an email to opendatakit...@googlegroups.com.
mitche...@gmail.com
