Error Connecting to odk aggregate from odk collect
Hello,
I installed odk aggregate on my laptop computer running on windows 7 and i as well downloaded and installed odk collect on my samsung s7. i am trying to get a blank form from odk aggregate from odk collect. unfortunately it throws error message as follows.
Form listing failed. parsing with connect to 192.178.1.2:8080/ODKAggregate/formList: failed to connect to connect to /192.168.1.2(port 6881) from /192.168.1.5(port 58226) after 30000ms while accessing https://192.178.1.1.2:6881/ODKAggregate/formList
I am using postgre9.6 and tomcat8
I am not using an SSL certificate
Thanks in advance
2 posts were split to a new topic: Aggregate VM with static IP not working
A post was merged into an existing topic: Aggregate VM with static IP not working
Hi @Lai, you error message has a bunch of different IP addresses and ports and I think that's the root of the problem. For Aggregate to work, you need a fully qualified domain name (or a static IP address). You'll need to put that name/address into the installer and connect to Aggregate with that name/address.
If the above isn't clear, I'd recommend you try starting with the VM (https://docs.opendatakit.org/aggregate-vm/) and see if that works better for you.
