I have created an encrypted form for my survey. The encryption process seems to be working but when I try to upload the xml files into the server I get the message:
Error: Not Found (404) at http://srcokd.appspot....
Things I have checked:
- I am sure the original xml file is in the server (Form management tab): I have actually downloaded this file into the smart phone to use it for the surveys.
- When I look at the filled xml files they look encrypted fine to me.
- I have tried to do the same things with a different (not encrypted) survey and it works fine: the transfer is fine and I can see the file in the aggregate server ( so this seems to rule out the user/password/connexion kind of errors).
I have also seen some where that xml form files in the server should not contain the submission_url field but when I have tried the encryption doesn't work anymore.
I have also tried to directly decode the file using Briefcase in my PC but it doesn't work. When I try to pull the files I get the following message:
resolving against briefcase form definitions
unable to copy form definition and/or media folder: Form definitions are incompatible.
FAILED.
I have 2 questions here:
- Any ideas on what the problem might be to do the transfert? As far as I have understood in the website once the file is in the aggregate server ODK Briefcase should be able to decode the xml files.
- Is it possible to directly decode the files using Briefcase without going through the Aggregate server? Based on what I have seen in the website I don't think so but I would like to be sure so as not to keep trying.
Have a good weekend,
Arturo
Food_security_survey_v6_Encrypted.xml (19 KB)
Arturo,
Submission action url should be https://srcokd.appspot.com/submission.
Looks like you are missing the /submission. You can fix this in the
submission_url column in your settings worksheet. Also make sure your
url in the settings of ODK Collect point to https, not http.
FAILED.
Arturo
