I have big problems getting my form to work and upload it to the Aggregate
server (I use version 0.9.8 on google App engine)
I'm trying to make a simple option field(with two options) in my form, but
it won't parse? I'm using the ODK build site to make my form.
I'm getting this error when trying to Validate the form: (and I have the
data id tag in place)
Checking form...
Parsing form...
Title: "lowLevelTest2" java.lang.NullPointerException
at org.javarosa.xform.parse.XFormParser.parseItem(XFormParser.java:899)
at
org.javarosa.xform.parse.XFormParser.parseControl(XFormParser.java:610)
at org.javarosa.xform.parse.XFormParser$7.handle(XFormParser.java:150)
and this when uploading to Aggregate:
Error: Problem with JavaRosa Parsing Form:null
But it seems very strange to me, and I'm not that into XML, but It's
like there is more tags end tags
I'll tryed to change the tag in the <h:body> to Gul</
value>. (Its allready in the <h:head> part)
Now I get it error :
Checking form...
[Fatal Error] lowLevelTest2.xml:36:9: The element type "value" must be
terminated by the matching end-tag "".
On 11 Okt., 14:53, Andrew Marder wrote:
> Hi Martin,
> One possible problem is that your items have no values. You might try
> replacing with something like Gul.
> Andrew
> On Tue, Oct 11, 2011 at 6:32 AM, Martin Mosgaard Knudsen wrote:
> > Hi ODK team
> > Checking form...
> > Parsing form...
> > at
> > This is my form:
> > > xmlns:h="http://www.w3.org/1999/xhtml"
> > xmlns:ev="http://www.w3.org/2001/xml-events"
> > xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> > xmlns:jr="http://openrosa.org/javarosa">
> > lowLevelTest2
> > Her kan du svare?
> > Gul
> > Grøn
> > Can anybody help me to locate the problem? This would be really great if I
> > can get this to work...
> > Thanks!
> > Venlig hilsen
> > Dommervænget 22 1. tv
> > 4000 Roskilde
> > tlf.: 61 69 14 57
> > email: martinmosga...@gmail.com / mm...@hotmail.com
> > Options:http://groups.google.com/group/opendatakit?hl=en- Skjul tekst i anførselstegn -
> - Vis tekst i anførselstegn -
The are more end tags in begining task??? Does this mean anything? I'm
not a big XML-Shark.
> Hi Martin,
> Andrew
> > Hi ODK team
> > Checking form...
> > Parsing form...
> > at
> > This is my form:
> > lowLevelTest2
> > Her kan du svare?
> > Gul
> > Grøn
> > Thanks!
> > Venlig hilsen
> > 4000 Roskilde
> > tlf.: 61 69 14 57
Andrew
> Hi ODK team
> Checking form...
> Parsing form...
> at
> This is my form:
> lowLevelTest2
> Her kan du svare?
> Gul
> Grøn
> Thanks!
> Venlig hilsen
> 4000 Roskilde
> tlf.: 61 69 14 57
> email: martinmosgaard@gmail.com / mmk01@hotmail.com
The problem is in the select1 definition, as Andrew identified. You have:
The tags here must contain a value that will be stored in the
submission record. This is like a coding value in an old-style
questionnaire. As written, you've defined a select1 but both of the choices
(option0 and option1) will code to nothing. A valid select1 would be:
option0ChoiceCodingValue
option1ChoiceCodingValue
On Tue, Oct 11, 2011 at 6:42 AM, Martin Mosgaard Knudsen < martinmosgaard@gmail.com> wrote:
Hi Andrew
Thanks for fast reply.
Checking form...
Aggregate
but
the
Checking form...
Parsing form...
at
at
at
Checking form...
[Fatal Error] lowLevelTest2.xml:37:9: The element type "value" must be
It do not like the inserted tag!? (I tryed inserting a new end
tag, but it just crash)
> Mitch
> On Tue, Oct 11, 2011 at 6:42 AM, Martin Mosgaard Knudsen < martinmosga...@gmail.com> wrote:
> > Hi Andrew
> > I'll tryed to change the tag in the to Gul > value>. (Its allready in the part)
> > Checking form...
> > > Hi Martin,
> > > Andrew
> > > > Hi ODK team
> > Aggregate
> > but
> > the
> > > > Checking form...
> > > > Parsing form...
> > > > at
> > > > at
> > > > at
> > > > This is my form:
> > > > lowLevelTest2
> > > > Her kan du svare?
> > > > Gul
> > > > Grøn
> > if I
> > > > Thanks!
> > > > Venlig hilsen
> > > > 4000 Roskilde
> > > > tlf.: 61 69 14 57
> > > > Options:http://groups.google.com/group/opendatakit?hl=en-Skjul tekst
> > i anførselstegn -
> Mitch Sundt
> Software Engineerhttp://www.OpenDataKit.org
> University of Washington
> mitchellsu...@gmail.com- Skjul tekst i anførselstegn -
On Wed, Oct 12, 2011 at 12:25 AM, Martin Mosgaard Knudsen wrote:
> Hi Mitch
> I tryed both what you and Andrew described: se the code here:
> http://dpaste.com/632736/
> But now gets this error:
> Checking form...
>> Mitch
>> > Hi Andrew
>> > I'll tryed to change the tag in the to Gul> > value>. (Its allready in the part)
>> > Checking form...
>> > > Hi Martin,
>> > > Andrew
>> > > > Hi ODK team
>> > Aggregate
>> > but
>> > the
>> > > > Checking form...
>> > > > Parsing form...
>> > > > at
>> > > > at
>> > > > at
>> > > > This is my form:
>> > > > lowLevelTest2
>> > > > Her kan du svare?
>> > > > Gul
>> > > > Grøn
>> > if I
>> > > > Thanks!
>> > > > Venlig hilsen
>> > > > 4000 Roskilde
>> > > > tlf.: 61 69 14 57
>> > i anførselstegn -
>> Mitch Sundt
I still got the same error: (I understand more of the XML now, but not
enought to make it right)
Checking form...
[Fatal Error] lowLevelTest2.xml:17:13: The element type "value" must
be terminated by the matching end-tag "".
On 12 Okt., 10:51, Gaetano Borriello wrote:
> Change line 13 to:
> Here is question text
> and line 16 to:
> and here is hint text
> > Hi Mitch
> > Checking form...
> >> Mitch
> >> > Hi Andrew
> >> > I'll tryed to change the tag in the to Gul >> > value>. (Its allready in the part)
> >> > Checking form...
> >> > > Hi Martin,
> >> > > Andrew
> >> > > > Hi ODK team
> >> > Aggregate
> >> > but
> >> > the
> >> > > > Checking form...
> >> > > > Parsing form...
> >> > > > at
> >> > > > at
> >> > > > at
> >> > > > This is my form:
> >> > > > lowLevelTest2
> >> > > > Her kan du svare?
> >> > > > Gul
> >> > > > Grøn
> >> > if I
> >> > > > Thanks!
> >> > > > Venlig hilsen
> >> > > > 4000 Roskilde
> >> > > > tlf.: 61 69 14 57
> >> > > > Options:http://groups.google.com/group/opendatakit?hl=en-Skjultekst
> >> > i anførselstegn -
> >> Mitch Sundt
On Wed, Oct 12, 2011 at 1:05 PM, Martin Mosgaard Knudsen wrote:
> Thank again for trying to help.
> I maked the change, see here:
> http://dpaste.com/632943/ (I'll maked the code easier to look at)
> Checking form...
>> Change line 13 to:
>> and line 16 to:
>> > Hi Mitch
>> > Checking form...
>> >> Mitch
>> >> > Hi Andrew
>> >> > I'll tryed to change the tag in the to Gul> >> > value>. (Its allready in the part)
>> >> > Checking form...
>> >> > > Hi Martin,
>> >> > > Andrew
>> >> > > > Hi ODK team
>> >> > Aggregate
>> >> > but
>> >> > the
>> >> > > > Checking form...
>> >> > > > Parsing form...
>> >> > > > at
>> >> > > > at
>> >> > > > at
>> >> > > > This is my form:
>> >> > > > lowLevelTest2
>> >> > > > Her kan du svare?
>> >> > > > Gul
>> >> > > > Grøn
>> >> > if I
>> >> > > > Thanks!
>> >> > > > Venlig hilsen
>> >> > > > 4000 Roskilde
>> >> > > > tlf.: 61 69 14 57
>> >> > i anførselstegn -
>> >> Mitch Sundt
have:
the
choices
be:
