Hi Guys,
I came across many posts talking about this problem, I passed my form to
ODK validate, it is valid, however the server keeps showing the message
whenever I try to upload this new form.
"Error: Problem with JavaRosa Parsing Form:
org.opendatakit.aggregate.exception.ODKIncompleteSubmissionData: Javarosa
failed to construct a FormDef. Is this an XForm definition?"
Any thought on this?
Here is the validation results:
Parsing form...
Title: "Wash community profile v1.0 ????? ??????? ??????"
Xform parsing completed! See above for any warnings.
Dynamic select question has no choices! [instance(subdistrict)/root/item].
If this occurs while filling out a form (and not while saving an incomplete
form), the filter condition may have eliminated all the choices. Is that
what you intended?
Dynamic select question has no choices! [instance(town)/root/item]. If this
occurs while filling out a form (and not while saving an incomplete form),
the filter condition may have eliminated all the choices. Is that what you
intended?
warning: previous choices not cleared out
what you intended?
intended?
what you intended?
intended?
what you intended?
intended?
what you intended?
intended?
what you intended?
intended?
what you intended?
intended?
what you intended?
intended?
Xform is valid! See above for any warnings.
