Dear User
I have to upload a form and I get this error
Error: Problem with JavaRosa Parsing Form: org.opendatakit.aggregate.exception.ODKIncompleteSubmissionData: The version string must be an integer less than 2147483648
How can i solve this?
Pierre
I ma using odk agregrate (cloud). pleased find attached the xml form i want
to upload in the server.
Thanks a lot
Opportunite.xml (85.1 KB)
2015-03-10 10:43 GMT-07:00 :
Dear User
Pierre
I believe this is a problem with FormHub when generating an automatic
version string.
The version string can be manually set on the settings sheet.
The string needs to have a numeric value that is less than 2**32.
We recommend using a format of:
yyyymmddvv
where vv is the number of the revision of this form on the given day. E.g.,
2015031005
would be the 5th revision on 2015-03-10
The generated version number that FormHub produces has 2 extra digits:
On Tue, Mar 10, 2015 at 12:48 PM, Pierre Anthony Garraud < pagarraud1@gmail.com> wrote:
want to upload in the server.
Thanks a lot
2015-03-10 10:43 GMT-07:00 bridessondage@gmail.com:
Dear User
Pierre
Please could you tell me how to correct it ?
Pierre
2015-03-10 13:21 GMT-07:00 Mitch Sundt :
version string.
yyyymmddvv
E.g.,
2015031005
Thanks a lot
Dear User
Pierre
Groups "ODK Community" group.
The version string can be manually set on the settings sheet of your Excel
spreadsheet.
See the ODK example XLSForm
http://opendatakit.org/wp-content/uploads/2013/06/sample_xlsform.xls
If FormHub insists on using its own version string and will not respect the
version entered on the settings sheet, you will need to switch to use
XLSForm, either from our website, from the Windows stand-alone version, or
from some other compatible source.
On Tue, Mar 10, 2015 at 1:28 PM, Pierre Anthony Garraud < pagarraud1@gmail.com> wrote:
Pierre
2015-03-10 13:21 GMT-07:00 Mitch Sundt mitchellsundt@gmail.com:
version string.
yyyymmddvv
E.g.,
2015031005
Thanks a lot
Dear User
Pierre
