I have followed this link https://github.com/opendatakit/aggregate/blob/master/docs/app-engine.md for minimum AppEngine eclipse setup and when I try to debug as in 20th step following exceptions are thrown.Please let me know whats the solution for this.
Exception encountered during context initialization - cancelling refresh attempt: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'datastore' defined in class path resource [odk-settings.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Failed to instantiate [org.opendatakit.common.persistence.engine.gae.DatastoreImpl]: No default constructor found; nested exception is java.lang.NoClassDefFoundError: com/google/appengine/api/datastore/EntityNotFoundException
Jul 17, 2017 5:40:32 AM org.springframework.web.context.ContextLoader initWebApplicationContext
SEVERE: Context initialization failed
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateBean(AbstractAutowireCapableBeanFactory.java:1110)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:1054)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:512)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:482)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:306)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:230)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:302)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:197)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:754)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:866)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:542)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:444)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:326)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:107)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:548)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:136)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1250)
at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:517)
at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:467)
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:50)
at org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:130)
at org.mortbay.jetty.Server.doStart(Server.java:224)
at com.google.appengine.tools.development.JettyContainerService.startContainer(JettyContainerService.java:268)
at com.google.appengine.tools.development.AbstractContainerService.startup(AbstractContainerService.java:284)
at com.google.appengine.tools.development.ManualInstanceHolder.startUp(ManualInstanceHolder.java:77)
at com.google.appengine.tools.development.AbstractModule.startup(AbstractModule.java:87)
at com.google.appengine.tools.development.Modules.startup(Modules.java:105)
at com.google.appengine.tools.development.DevAppServerImpl.doStart(DevAppServerImpl.java:271)
at com.google.appengine.tools.development.DevAppServerImpl.access$000(DevAppServerImpl.java:47)
at com.google.appengine.tools.development.DevAppServerImpl$1.run(DevAppServerImpl.java:219)
at com.google.appengine.tools.development.DevAppServerImpl$1.run(DevAppServerImpl.java:217)
at java.security.AccessController.doPrivileged(Native Method)
at com.google.appengine.tools.development.DevAppServerImpl.start(DevAppServerImpl.java:217)
at com.google.appengine.tools.development.DevAppServerMain$StartAction.apply(DevAppServerMain.java:359)
at com.google.appengine.tools.util.Parser$ParseResult.applyArgs(Parser.java:47)
at com.google.appengine.tools.development.DevAppServerMain.run(DevAppServerMain.java:223)
at com.google.appengine.tools.development.DevAppServerMain.main(DevAppServerMain.java:214)
Caused by: org.springframework.beans.BeanInstantiationException: Failed to instantiate [org.opendatakit.common.persistence.engine.gae.DatastoreImpl]: No default constructor found; nested exception is java.lang.NoClassDefFoundError: com/google/appengine/api/datastore/EntityNotFoundException
at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:85)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$4.run(AbstractAutowireCapableBeanFactory.java:1097)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateBean(AbstractAutowireCapableBeanFactory.java:1094)
... 39 more
Caused by: java.lang.NoClassDefFoundError: com/google/appengine/api/datastore/EntityNotFoundException
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.getDeclaredConstructor(Unknown Source)
at org.springframework.beans.factory.support.SimpleInstantiationStrategy$1.run(SimpleInstantiationStrategy.java:75)
at org.springframework.beans.factory.support.SimpleInstantiationStrategy$1.run(SimpleInstantiationStrategy.java:72)
at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:72)
... 42 more
Caused by: java.lang.ClassNotFoundException: com.google.appengine.api.datastore.EntityNotFoundException
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at com.google.appengine.tools.development.IsolatedAppClassLoader.loadClass(IsolatedAppClassLoader.java:195)
... 50 more
Jul 17, 2017 5:40:32 AM com.google.apphosting.utils.jetty.JettyLogger warn
WARNING: Failed startup of context com.google.appengine.tools.development.DevAppEngineWebAppContext@90ea59f{/,C:\Users\vamshi\Downloads\ODKAgggrgateNew\aggregate.metadata.plugins\org.eclipse.wst.server.core\tmp1\eclipse-ear\eclipse-n-background.war}
... 39 more
... 42 more
... 50 more
WARNING: Nested in org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'datastore' defined in class path resource [odk-settings.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Failed to instantiate [org.opendatakit.common.persistence.engine.gae.DatastoreImpl]: No default constructor found; nested exception is java.lang.NoClassDefFoundError: com/google/appengine/api/datastore/EntityNotFoundException:
