Angelo,
I don't think that, this will be possible, as long as the number of loops
is set at a constant number.
However, let's continue thinking of it, while waiting for what others
think.
best,
Le mardi 28 mars 2017 20:27:17 UTC+2, Angelo Lazzari a écrit :
Hi, for example i have a repeat with 3 questions in it... And i need the
user answer a maximum of 4 loops...but, the last question of the repeating
group is "do you need to insert another detail line?"
..if the user anwer is no i want to exit the loop even the total repeating
count isn't 4...
Hope my explanation now is ok
Thank you very much!!
Il mar 28 mar 2017 19:37 Amal altes...@gmail.com ha scritto:
Hi, Angelo
can you specify in which case the user will need to exit?
Le mardi 28 mars 2017 14:16:20 UTC+2, Angelo Lazzari a écrit :
Hi, anyone can help me? PLeeeeaasseee!!
Don't know if the aim is clear: i need to stop looping on a fixed number
of maximum loops but i want the user can exit the repeat when he/she
wants....
Please, any idea?
Thank you very much
Angelo
El jue., 23 mar. 2017 a las 16:27, Angelo Lazzari (lazzari...@gmail.com) escribió:
Hi, i googled a lot before post this thread but i wasn't be able to find a
solution to my simple problem. i found similar cases but no one was giving
me the correct solution.
As reported in the attached form i have a group with 4 maximum loops but i
have a question as final group question ...and y just wanted to end the
loop if the user answers Yes to the exit question.
Can you help me?
Thank you very much
Angelo
