Problème lors de l'exportation de formulaire de puis
http://build.opendatakit.org/
l’erreur {"Erreur": ". Quelque chose n'allait pas lorsque vous essayez de
publier sur Aggregate"}
Publishing to ODK Aggregate from Build only works if your ODK Aggregate is
hosted on Google AppEngine.
Publishing may also fail if the form is incomplete or somehow not correct.
If you are using Google AppEngine:
- Download ODK Validate (
http://code.google.com/p/opendatakit/downloads/detail?name=ODK Validate 1.3
for ODK Collect v1.3 and v1.2.jar ) - Download the form from Build to your computer.
- Double-click the downloaded ODK Validate jar to launch that application.
- Select the form you downloaded.
Any errors in the form will be reported in the output area.
Fix the errors using Build, and repeat 2-4 until there are no errors.
The form should then be able to be directly submitted from Build into ODK
Aggregate.
On Wed, Jul 10, 2013 at 4:02 AM, wrote:Problème lors de l'exportation de formulaire de puis
de publier sur Aggregate"}--
Spaces were breaking the link... trying this...
On Wed, Jul 10, 2013 at 2:11 PM, Mitch Sundt wrote:Publishing to ODK Aggregate from Build only works if your ODK Aggregate is
Publishing may also fail if the form is incomplete or somehow not correct.If you are using Google AppEngine:
1.3 for ODK Collect v1.3 and v1.2.jar )- Download the form from Build to your computer.
Aggregate.Mitch
