Exporting Grouped & Repeated data into CSV from aggregate
Hi Team, I created a survey with some questions organized into groups and
repeats for looping to help me collect tabular data.
Everything worked out well and I was able to submit data to the aggregate
server. However, at the aggregate when I try to export to csv so as to
eventually download, I see the table data that were organized into groups
are not exported. It gives me interface to view but not export or download.
Any advice on how I can import and download this grouped data together with
its survey?
Attached is the image at the aggregate.
Thanks.
Collins
Use ODK Briefcase to download the data to your computer, and Export to CSV
from within it.
It will produce a CSV file for the top-level group and each repeat group,
with fields to link those back together however you choose.
with its survey?
Thanks.
Collins
