I have deployed a solution where I call an external app here are the
details:
MANIFEST
<?xml version="1.0" encoding="utf-8"?>
<uses-sdk
android:minSdkVersion="17"
android:targetSdkVersion="17" />
<application
android:allowBackup="true"
android:icon="@drawable/ic_launcher"
android:label="@string/app_name"
android:theme="@style/AppTheme" >
<activity
android:name="org.path.collect.PathCollect"
android:label="@string/app_name" >
<intent-filter>
<action android:name="android.intent.action.MAIN" />
<category android:name="android.intent.category.LAUNCHER" />
</intent-filter>
</activity>
<activity
android:name="org.path.collect.GENERATE_INDEX_ID"
<intent-filter>
<action android:name="org.path.collect.android.GENERATE_INDEX_ID" />
<category android:name="category.DEFAULT"/>
</intent-filter>
</activity>
</application>
XML FILE
JAVA FILE
public class GENERATE_INDEX_ID extends Activity {
@Override
protected void onCreate(Bundle savedInstanceState) {
THE problem is I have always the error message defined in xml file even if
I install the APK properly : App not found
App not found
I have installed the latest version of ODK collect and the version that I
use for my external app is android 17, also I have installed the briefcount
example and it works !!! what is wrong with my APK or ODK configuration ?
pathtab2,
That's great news that the example app works. Have you tried rebuilding it
and confirming that your rebuilt version still works? If not => it's
something in your build environment. If so => it's just a matter of
carefully comparing that example project with yours: what's different?
Chris
details:
MANIFEST
<uses-sdk
<application
<activity
<intent-filter>
<activity
<intent-filter>
</application>
XML FILE
JAVA FILE
@Override
App not found
