Hi everyone,
I am trying to use external select on my form, but every time I try convert it in to a xform it gets rejected because it says for my select_one_external the "list name is not in the choices sheet". I am confused because the list name is in the external_choices sheet, as I thought it should be.
I have looked through the South Sudan sheet and copied the way they have done it.
any advice would be appreciated. The form is attached.
Sophie
SR_Form_v2.xls (246 KB)
Hi Sophie,
The first level of a cascading select needs to be in choices and not
external_choices. Move provinces to the choices sheet and change that
question from select_one_external to select_one.
On Thu, Jun 16, 2016 at 10:58 AM, sophie.m.roden@gmail.com wrote:
Hi everyone,
Sophie
