I downgraded Tomcat to 6 and Java to 7. however, I still get challenges.
On Localhost, when I try to start ODKAggregate in Tomcat mgr gui this is
what I receive(image) below; Tomcat logs attached
https://lh3.googleusercontent.com/-1rSw9o7i7J4/VvarFCEhlGI/AAAAAAAAAAM/hFGvwsFN44AxaVZZiG0Y7jaQaJAnDAPcg/s1600/Odkagregate.gif
*And on Google AppEngine *
Mar 26, 2016 6:34:06 PM
com.google.appengine.tools.info.RemoteVersionFactory getVersion
INFO: Unable to access
https://appengine.google.com/api/updatecheck?runtime=java&release=1.9.32
×tamp=1449775954&api_versions=['1.0']
javax.net.ssl.SSLHandshakeException:
sun.security.validator.ValidatorException: PKIX path building failed:
sun.security.provider.certpath.SunCertPathBuilderException: unable to find
valid certification path to requested target
at sun.security.ssl.Alerts.getSSLException(Unknown Source)
at sun.security.ssl.SSLSocketImpl.fatal(Unknown Source)
at sun.security.ssl.Handshaker.fatalSE(Unknown Source)
at sun.security.ssl.ClientHandshaker.serverCertificate(Unknown Source)
at sun.security.ssl.ClientHandshaker.processMessage(Unknown Source)
at sun.security.ssl.Handshaker.processLoop(Unknown Source)
at sun.security.ssl.Handshaker.process_record(Unknown Source)
at sun.security.ssl.SSLSocketImpl.readRecord(Unknown Source)
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(Unknown Source)
at sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source)
at sun.net.www.protocol.https.HttpsClient.afterConnect(Unknown Source)
at
sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(Unknown
Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown
Source)
at
sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(Unknown
Source)
at java.net.URL.openStream(Unknown Source)
at
com.google.appengine.tools.info.RemoteVersionFactory.getVersion(RemoteVersionFactory.java:76)
at
com.google.appengine.tools.info.UpdateCheck.getApplicationVersionInfo(UpdateCheck.java:153)
at
com.google.appengine.tools.info.UpdateCheck.maybePrintNagScreen(UpdateCheck.java:361)
at com.google.appengine.tools.admin.AppCfg.(AppCfg.java:189)
at com.google.appengine.tools.admin.AppCfg.(AppCfg.java:128)
at com.google.appengine.tools.admin.AppCfg.main(AppCfg.java:124)
Caused by: sun.security.validator.ValidatorException: PKIX path building
failed: sun.security.provider.certpath.SunCertPathBuilderException: unable
to find valid certification path to requested target
at sun.security.validator.PKIXValidator.doBuild(Unknown Source)
at sun.security.validator.PKIXValidator.engineValidate(Unknown Source)
at sun.security.validator.Validator.validate(Unknown Source)
at sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source)
at sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source)
at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source)
... 19 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException:
unable to find valid certification path to requested target
at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown
Source)
at java.security.cert.CertPathBuilder.build(Unknown Source)
... 25 more
Reading application configuration data...
Mar 26, 2016 6:34:07 PM
com.google.apphosting.utils.config.IndexesXmlReader readConfigXml
INFO: Successfully processed D:/AAODK/ODK
Aggregate/ODKAggregate\WEB-INF/datastore-indexes.xml
Beginning interaction for module default...
Unable to update app: sun.security.validator.ValidatorException: PKIX path
building failed:
Please see the logs
[C:\Users\Morska\AppData\Local\Temp\appcfg4045492412902036732.log] for
further information.
---- WEBSITE COMPLETE - BEGIN BACKEND ----
Mar 26, 2016 6:34:11 PM
at
Source)
Source)
at
Source)
at
at
at
... 19 more
Source)
... 25 more
Warning: This application uses Backends, a deprecated feature that has
been replaced by Modules, which offers additional functionality. Please
convert your backends to modules as described at:
https://developers.google.com/appengine/docs/java/modules/converting.
building failed:
Please see the logs
[C:\Users\Morska\AppData\Local\Temp\appcfg6683463887864161701.log] for
*---END-SCRIPT-FAILURE--- *
On Monday, March 14, 2016 at 3:36:47 PM UTC+3, Yaw Anokwa wrote:
Read your Tomcat logs for clues on what the problem is.
On Fri, Mar 11, 2016 at 3:35 PM, odkd...@gmail.com wrote:
Hello,
I am running Apache Tomcat 7 with java 8 and xampp server on windows 7.
I am
trying to install ODKaggregate but I get this error message
HTTP Status 404 - /ODKAggregate. The ODKaggregate appn. is loaded in
tomcat
but doesn't start and when I start it in tomcat manager, I get this "
FAIL -
Application at context path /ODKAggregate could not be started" I need
assistance. Thanks
Groups
an
