Hello,
See the attached output after uninstalling java and then installing the
said version and finally re-runn of the said "uploadAggregateToAppEngine.
hta" file
Regards
Simon
after_java_installation.txt (5.09 KB)
Hello,
hta" file
Regards
Simon
The upload worked (the 500 server errors did not occur), so your ODK
Aggregate should now be completely installed and operational.
The re-install of Java did not resolve this warning:
WARNING: Could not open/create prefs root node Software\JavaSoft\Prefs
at root 0x80000002. Windows RegCreateKeyEx(...) returned error code 5.
This does not seem to affect anything we are doing; I would ignore it for
now.
If you ever have any problems with Java applications running locally (e.g.,
ODK Briefcase), you might follow the instructions on the web for how to fix
this by creating certain registry entries in Windows, but doing that
manually always introduces a risk of damaging your system. Unless you are
comfortable with that, I would leave good enough alone.
Hello,
hta" fileRegards
SimonOn Friday, January 30, 2015 at 12:13:37 AM UTC+3, Mitch Sundt wrote:
Thank you for including the full txt from the progress dialog.
Two different errors are indicated:
(1) there seems to be an error sending the "cron job" configurations to
Google AppEngine. I have not seen this error before. This can affect the
performance of ODK Aggregate when using publishers or exporting data to CSV
or KML files. I.e., normal operations will work fine, but anything that
'works in the background' may break because the "cron job" configuration
controls these background activities.(2) there seems to be an error in the installation of Java on your
computer. You might try uninstalling Java and downloading and running a
newer Java 7 installer http://www.oracle.com/technetwork/java/javase/
downloads/jre7-downloads-1880261.htmlI do not believe (1) is related to (2), and from the errors, I suspect
(2) does not impact the uploader in any significant way.w.r.t. (1), try re-running the upload script by going into the ODK
Aggregate directory (this is NOT the folder accessible via the Start menu,
but is found using the File Explorer) and double-clicking the
"uploadAggregateToAppEngine.hta" file. Do you still get this error?It is hopefully a transient failure that Google has fixed.
On Wed, Jan 28, 2015 at 11:25 PM, Simon Muchemi smuch...@googlemail.com wrote:
Dear all,
I have been following this conversation especially after Zaixing started
getting some error during installation of ODK but by then i started with
ODK Aggregate v1.4.4 windows-installer.
I actually got some error that were close to what Zaixing was
getting.Surely i tried it severally before my disk generated some problem /
error due to some problem i did know but later i mounted another hardisk on
my computer and installed window 7.I have just decided to enmbark on installation of the same version of
odk that i was installing initially (ODK Aggregate v1.4.4) after doing this
installation am getting the attached output.You can also check the attached
word document to see the last portion of theUpload progress:
Noticed from the file there is some few hitch.But when refreshing my
instances in the dashboard it has changed from* no deployment* to
Running.I didn't believe !!! I have visited the instancefrom the brwoser and
work very ok.I have been able to change the superuser password accordingly.Please do check the attached file and see if there is anything that need
to be address with the installer version or may be on my computerI can Cheer for the time being !!!!
Would be eager to hear from all
Kind request
Simon
On Wednesday, January 21, 2015 at 9:32:45 PM UTC+3, Mitch Sundt wrote:
Re-run the installer, specify a different username, upload the files to
your appengine application ID, and try logging in using the 'aggregate'
password.By supplying a different username, that new username will be
initialized to have the 'aggregate' password when ODK Aggregate starts up.Once you can successfully log in, you can delete the other super-user
usernames or change the password on the one you want to keep.On Wed, Jan 21, 2015 at 3:53 AM, Gopal Dey gde...@gmail.com wrote:
You are welcome Zai Xing. J
All the best! Cheers!
GopalOn Tue, Jan 20, 2015 at 11:40 PM, Zaixing Zhang <zhangzai...@gmail.com wrote:
Hi Gopoal,
Thanks so much. It works! And very easy!
All the best to you.
Zai Xing
On Jan 21, 2015 12:30 AM, gde...@gmail.com wrote:On Wednesday, January 14, 2015 at 2:47:11 AM UTC+6, Zaixing Zhang wrote:
I tried to install ODK aggregate v1.4.4. when it finished. I found
a folder named "ODK Aggregate" under the "programmes". However, it is
empty!. Hence i do not know where to start to use the Aggregate. Could you
kindly telle me what is the problem?Regards and look forward to hearing from you soon.
Zaixing
A good way to avoid the complex installation of ODK is to use ONA.
Just upload your XLSForm form (questionnaire) there and integrate it
with ODK apps installed in your android. Life is much easier here!Best,
Gopoal--
You received this message because you are subscribed to a topic in
the Google Groups "ODK Community" group.
To unsubscribe from this topic, visit https://groups.google.com/d/to
pic/opendatakit/hKjPk7lgU0g/unsubscribe.
opendatakit...@googlegroups.com.
mitche...@gmail.com--
Mitch surely yes,
The odk agreggate installation was noticed to be complete and I tested it.it
received data from collect and also published to fusion table without
problem so far and i will agree with you for now.
Thank you for your support up to date.
Regards
Simon
Aggregate should now be completely installed and operational.The re-install of Java did not resolve this warning:
WARNING: Could not open/create prefs root node Software\JavaSoft\Prefs at
root 0x80000002. Windows RegCreateKeyEx(...) returned error code 5.This does not seem to affect anything we are doing; I would ignore it for
now.If you ever have any problems with Java applications running locally
(e.g., ODK Briefcase), you might follow the instructions on the web for how
to fix this by creating certain registry entries in Windows, but doing that
comfortable with that, I would leave good enough alone.Hello,
hta" fileRegards
SimonThank you for including the full txt from the progress dialog.
http://www.oracle.com/technetwork/java/javase/downloads/jre7-downloads-1880261.htmlI do not believe (1) is related to (2), and from the errors, I suspect
Dear all,
started getting some error during installation of ODK but by then i started
with ODK Aggregate v1.4.4 windows-installer.
instances in the dashboard it has changed from no deployment to Running.I didn't believe !!! I have visited the instancefrom the brwoser and
need to be address with the installer version or may be on my computerI can Cheer for the time being !!!!
Kind request
Simon
to your appengine application ID, and try logging in using the 'aggregate'
password.
usernames or change the password on the one you want to keep.You are welcome Zai Xing. J
GopalHi Gopoal,
Zai XingHi,
found a folder named "ODK Aggregate" under the "programmes". However, it is
Zaixing
it with ODK apps installed in your android. Life is much easier here!Best,
Gopoal--
https://groups.google.com/d/topic/opendatakit/hKjPk7lgU0g/unsubscribe.
send an email to opendatakit...@googlegroups.com.
mitchellsundt@gmail.com--
