Hello, does anybody know how to combine in a single field text and integer?
I need to enter an ID code that contains letters and numbers at the same
time but don't know which type of field I should use! Thanks
Hi Camilla,
You can use a text field. That will allow both letters and numbers (and
punctuation, and basically everything).
Chris
On Mon, Apr 14, 2014 at 12:40 AM, camilla fabbri wrote:Hello, does anybody know how to combine in a single field text and
integer? I need to enter an ID code that contains letters and numbers at
the same time but don't know which type of field I should use! Thanks--
