Hello,
We are using odk collect to fill multiple forms. To link the forms together
we are using a "Student ID" field. Now, we would like to lookup the
"Student ID" from ODK aggregate given a student name. Does ODK aggregate
expose an API with a functionality to filter the forms based on some
criteria, because I see this functionality in the ODK Aggregate web
application.
Would you please recommended a way to approach this problem.
Meera
For significant data processing, we recommend using an external system for
data analysis.
You can apply a filter to the data being published, and you can apply a
filter to CSV exports (the filter applies to values outside of any repeat
groups, and not to the repeats within that table).
The filters only work on non-multiple-choice fields, and on fields outside
of any repeat groups. If you are using a MySQL database, only roughly the
first 200 fields can be used in the filter (on AppEngine and with the
PostgreSQL database, this limitation applies to the first 3900 fields and
is unlikely to occur in practice).
On Fri, Oct 17, 2014 at 10:06 PM, Meera Kamath wrote:
Hello,
together we are using a "Student ID" field. Now, we would like to lookup
the "Student ID" from ODK aggregate given a student name. Does ODK
aggregate expose an API with a functionality to filter the forms based on
some criteria, because I see this functionality in the ODK Aggregate web
application.
Meera
"ODK Developers" group.
I am still confused, Let me rephrase my question. How do I filter the data
available in ODK Aggregate programmatically?
Meera
data analysis.
On Fri, Oct 17, 2014 at 10:06 PM, Meera Kamath meera.kamath12@gmail.com wrote:
Hello,
application.
Meera
https://groups.google.com/d/topic/opendatakit-developers/UmH7gwOX3Ts/unsubscribe
We don't expose a programmatic way to do this.
Meera
for data analysis.
outside of any repeat groups. If you are using a MySQL database, only
roughly the first 200 fields can be used in the filter (on AppEngine and
with the PostgreSQL database, this limitation applies to the first 3900
fields and is unlikely to occur in practice).
Hello,
application.
Meera
an email to opendatakit-developers+unsubscribe@googlegroups.com.
