I have a situation with two different repeat question sets, the values recorded in the first repeat set should be used in a skip logic for the next repeat set. Is there a possibility to achieve this with odk? Sorry the previous answers in this thread have not made this so clear to me. I am using aggregate 1.4 .Thanks!
Could you describe a sample case?
for instance, I have a repeat question which collects the age of infants , then another repeat question in a different repeat group to use the date of birth response to check if the infant should receive some intervention. I will now have two repeat instances with different questions, but the latter needs to check on the former for relevance purposes. Please tell if I dont make sense @Grzesiek2010
