Dear all,
I was working on modification in ODK buid since past few months. There was
a bug, which is it shows the label instead of constraint message.
The problem was in
*LIne 436. *There was
addTranslation(control.label, xpath + control.name + ':constraintMsg',
translations);
It should be
addTranslation(control.invalidText, xpath + control.name + ':constraintMsg',
translations);
Thank you All
Filed at https://github.com/clint-tseng/odkbuild/issues/36. If you can
submit a pull request that fixes the issue, it'll be more likely to
get fixed quickly.
On Tue, Mar 18, 2014 at 6:30 AM, Mobinul Islam mobinul@mpower-health.com wrote:
Dear all,
I was working on modification in ODK buid since past few months. There was a
The problem was in
https://github.com/clint-tseng/odkbuild/blob/master/public/javascripts/data.js
LIne 436. There was
translations);
It should be
translations);
Thank you All
