Good morning all,
Working on a project that collects patient initials only to maintain
anonymity. The end user would like to collect up to 4 letters in ALL CAPS.
My question -- is there an appearance tag that would present the input
keyboard already in caps lock?
I'm thinking of something similar to the example at http://opendatakit.org/help/form-design/examples/
where a string field is modified to display numbers and a few other
characters by adding an appearance tag to the body. Like this
What other options are available to go with "appearance"? I'm hoping for
appearance="AllCaps" or appearance="uppercase"
Thanks always for great input from the ODK community.
Alternatively, you prevent a user from swiping the next prompt by
using a regular expression that only allows upper case characters.
On Mon, Nov 5, 2012 at 8:46 AM, Ruth Little wrote:
> Good morning all,
> R
Thanks for the quick response Yaw.
I found the constraint but the client wanted the keyboard to default to all
caps (saving the user a doubletap on caps).
I'll pass it along to our programmer, but its probably not worth the time
IMHO
Cheers!
On Monday, November 5, 2012 12:06:11 PM UTC-5, Yaw Anokwa wrote:
> Ruth,
> You can't do this without changing the code in Collect. The best way
> to do that is to hire a dev from
> http://opendatakit.org/help/help-for-hire.
> Yaw
> On Mon, Nov 5, 2012 at 8:46 AM, Ruth Little <ru...@kestrel-tech.com> wrote:
> > Good morning all,
> CAPS.
> for
> > R
