Form not validity due to entity outside repeat group
I have xls form name repeatcount.xlsx that saves to an entity called birthdays.The entity birthdays has a propertity called summry.both the entity and the property are not in a repeat group but their are repeat groups in the form for some processing.Form validation failed when loading to centreal(screenshot atteched
repeatcounvalidationerror
attached excel form defination(
repeatcount.xlsx (589.8 KB)
Checked entity names and properties to ensure accuracy and that they are not in a repeat.
Done
You're going to find this silly... the problem is the blank line before your entity declaration. We have a pretty crude check to make sure only one entity is declared and it doesn't ignore blank lines. Hopefully removing that line lets you make progress!
