Hi All,
i have run into this issue with ODK Collect v1.22.4
color styling work fine to highlight a question but, copy and paste the same formatting into choices results in an output that reads: Yes rather than a red "yes".
The preview in Enketo works fine. Is it my phone? - Moto G5plus (Android 8.1.0), or an actual bug?
NB: an old Asus tablet also shows the same issue.
cheers,
jeff
Thanks for replying Grzesiek,
Sorry but i have just noticed that my original post didn't explain the issue properly - the form is a behemoth so i have cut out the relevant section.
In Enketo Preview it works as desired: the Project title is in red (as i want), in the repeat group when i select a beetle some options are coloured (the 4th down "Cryptocephalus" was made by copy-paste of the project form styling. i also used hex colours and they work fine too.
But, on my android, all i see is the actual style code words, ie: i see "< span style = " color:red " > Cryptocephalus< / span>" instead of a red worded "Cryptocephalus".
NB:i have added the extra spaces into the span coding,otherwise it doesn't display properly in this post
is it my device?
cheers, jeff abcl.xlsx (45.0 KB)
Thanks for reporting the issue and for your sample form which helped a lot. The problem is you used minimal appearance and we don't support styling with that appearance. I reported an issue https://github.com/opendatakit/collect/issues/3190 and will fix it.
Thanks!
