Hi all,
I want to add a question which asks for dose in mg/ml. Mg and ml will need to be two separate entries as the dose could be 25mg in 5ml. Is there a way to format this so the question looks like
____mg / ____ml
Thanks in advance,
Faran
Hi all,
____mg / ____ml
Thanks in advance,
Faran
I don't think you can format it exactly how you ask. In Collect, you can group multiple questions on the same screen using the field-list
appearance on a group. Is that enough?
Hi @danbjoseph
Thanks for your response!
If the questions are in the middle of a group, how would you suggest doing this? E.g.
begin_group
Q1
Q2
Q3
Q4 - mg
Q5 - ml
Q6
Q7
end_group
Faran
Are you using appearance
of field-list
on the big group?
If not, you can nest groups and place the appearance on the child group.
begin_group
Q1
Q2
Q3
begin_group (appearance = field-list)
Q4 - mg
Q5 - ml
end_group
Q6
Q7
end_group
You could also try something like this?
| type | name | label | required |
| integer | mg | Dose in mg? | yes |
| integer | ml | Dose in ml? | yes |
| acknowledge | confirm_dose | Please confirm that the dose is ${mg} mg / ${ml} ml | yes |
Hi @danbjoseph
I've incorporated both of those and that's worked perfectly - thank you very much!
Faran
