I'm assuming this is a result of not having a text/xml in the header of the
XML and 1.1.7 being more strict about it? I'm going to try this to see if
indeed that's the case but was just wondering if someone could confirm this
hunch.
ODK Collect checks the content type to verify it is text/xml during a fetch
of data it knows should be xml. If it gets a non-xml page, it is likely a
wi-fi and/or network login pages, and that should be reported to the user
differently from other errors.
Not sure whether it only accepts text/xml or also allows application/xml
On Tue, Nov 29, 2011 at 6:56 AM, Matt Berg wrote:
We've written our own custom backend to Collect.
Our formList looks like the following. It works fine for 1.1.5 but throws
the following error for 1.1.7
Form listing failed. ContentType: application/xml returned from formhub.org/mberg. formList is not text/xml.
the XML and 1.1.7 being more strict about it? I'm going to try this to see
if indeed that's the case but was just wondering if someone could confirm
this hunch.
this is the correct behavior as far as web standards are concerned.
> Mitch
>> Education_RevForHTI_ChadSheetsRemoved_EA_11-08
>> geopoint
>> nutrition_screening
>> tutorial
>> tutorial2
>> this hunch.
>> thanks,
>> Matt
> Mitch Sundt
> Software Engineer
> University of Washington
> mitchellsundt@gmail.com
fetch
throws
see
confirm
this hunch.
fetch
a
user
throws
to see
confirm
this hunch.
