Have a project in Mali and am having major issue with forms that use
accent characters in french. Using collect on Android the forms work,
however, the accent characters appear as question marks with black
backgrounds. We also are using JavaRosa on Nokia phones. Same forms
crash the app with an xform parsing exception. However, since the
JavaRosa app allows one to specify a different fetch server, I have
taken the same xml files and put them on the file system and used a
simple php script to put up the formList and send the phone the xml
file from disk storage. These work fine and the accent marks appear
properly.
Was wondering if anybody has a handle on this, with Aggregate, why
when the same xml is sent to the phone it does not work. Could it be
the fact the the form is stored in a BLOB and that the Java string
type (UTF-16). I have been able to verify that my workaround test and
Aggregate are sending the same header.
Thoughts??
John B. Murphy
jbmurphyUSA@gmail.com
Which version of Aggregate are you using? If you are using a 0.9.x
version then a fix contained in in the unreleased Aggregate 1.x is to
modify the response type variable to be
RESP_TYPE_XML = "text/xml";
to
RESP_TYPE_XML = "text/xml; charset=utf-8";
Waylon
> properly.
> Thoughts??
> John B. Murphy
To keep the thread up to date an issue was filed:
http://code.google.com/p/opendatakit/issues/detail?id=215&start=100
Thanks John for finding this issue!
Waylon
> to
> Waylon
>> properly.
>> Thoughts??
>> John B. Murphy
Waylon,
We have a project in Mali starting next week. Requires french language
forms. Is there anyway we can get the build scripts for Alpha6 with MySQL
back-end so we could apply that fix?
Or get a war with the fix in it?
No joy building uiexperiment.
Best
John
John B. Murphy
(617) 504-1531
> to
> Waylon
>> properly.
>> Thoughts??
>> John B. Murphy
Waylon,
Was just looking at the code,
note that
} else {
resp.setContentType(HtmlConsts.RESP_TYPE_XML);
in src/org/opendatakit/aggregate/servlet/FormXmlServlet.java
Will have no effect because it is below the call to PrinteWriter.
Just FYI
-john
> Waylon
>> to
>> Waylon
>>> properly.
>>> Thoughts??
>>> John B. Murphy
John B. Murphy
(617) 504-1531
John,
Mitch is working on building the new tree right now as he is switching
things to maven and there are some glitches still. Feel free to start
an email exchange with him directly msundt@cs.washington.edu (i
checked with Mitch and he said that would be best).
Waylon
On Tue, May 24, 2011 at 12:00 PM, John Murphy wrote:
> Waylon,
> Best
> John
> John B. Murphy
> (617) 504-1531
>> to
>> Waylon
>>> properly.
>>> Thoughts??
>>> John B. Murphy
Okay, cool.
John
John B. Murphy
(617) 504-1531
On May 24, 2011 3:05 PM, "W. Brunette" wrote:
> John,
> Waylon
>> Waylon,
>> Best
>> John
>> John B. Murphy
>> (617) 504-1531
>>> to
>>> Waylon
>>>> properly.
>>>> Thoughts??
>>>> John B. Murphy
Hello,
I had a similar issue with the form in displaying scripts in Hindi (One of
the Indian language) and we could overcome by tweaking the aggregate code:
src/odk/aggregate/servlet/FormXmlServlet.java:
Current :
xmlString = xmlString.toString();
resp.setCharacterEncoding(ServletConsts.ENCODE_SCHEME);
PrintWriter out = resp.getWriter();
Earlier/prior to above edit:
resp.setCharacterEncoding(“utf-8”)
Also, I tried to test by downloading the "test_accents.xml" from
http://code.google.com/p/opendatakit/issues/detail?id=215&start=100 and it
is worked for me.
Nayak
On Wed, May 25, 2011 at 12:37 AM, John Murphy wrote:
Okay, cool.
John
John B. Murphy
(617) 504-1531
On May 24, 2011 3:05 PM, "W. Brunette" wbrunette@gmail.com wrote:
John,
Waylon
On Tue, May 24, 2011 at 12:00 PM, John Murphy jbmurphyusa@gmail.com wrote:
Waylon,
MySQL
Best
John
John B. Murphy
(617) 504-1531
to
Waylon
properly.
Thoughts??
John B. Murphy
