Today I've been trying to set up ODK Aggregate using Google App Engine. I
downloaded the ODK Aggregate v1.4 windows-installer.exe and the set up went
fine, but when I try to log in, i just get this screen
What is shown if you hit the '+' on the logs page?
The log summaries are not detailed enough for me to diagnose your problem.
On Mon, Nov 18, 2013 at 2:42 AM, Julio Garcia Perez < juliogarcia@ideusingenieros.com> wrote:
Hi everyone, this is my first post here.
javax.servlet.ServletContext log: Initializing Spring root WebApplicationContext
I2013-11-18 18:22:27.776
org.springframework.web.context.ContextLoader initWebApplicationContext: Root WebApplicationContext: initialization started
I2013-11-18 18:22:28.710
org.springframework.context.support.AbstractApplicationContext prepareRefresh: Refreshing Root WebApplicationContext: startup date [Mon Nov 18 17:22:28 UTC 2013]; root of context hierarchy
I2013-11-18 18:22:29.276
org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions: Loading XML bean definitions from class path resource [odk-settings.xml]
E2013-11-18 18:22:29.278
org.springframework.web.context.ContextLoader initWebApplicationContext: Context initialization failed
org.springframework.beans.factory.BeanDefinitionStoreException: IOException parsing XML document from class path resource [odk-settings.xml]; nested exception is java.io.FileNotFoundException: class path resource [odk-settings.xml] cannot be opened because it does not exist
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:341)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:302)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:174)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:209)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:180)
at org.springframework.web.context.support.XmlWebApplicationContext.loadBeanDefinitions(XmlWebApplicationContext.java:125)
at org.springframework.web.context.support.XmlWebApplicationContext.loadBeanDefinitions(XmlWebApplicationContext.java:94)
at org.springframework.context.support.AbstractRefreshableApplicationContext.refreshBeanFactory(AbstractRefreshableApplicationContext.java:131)
at org.springframework.context.support.AbstractApplicationContext.obtainFreshBeanFactory(AbstractApplicationContext.java:530)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:444)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:383)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:283)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:111)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:548)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:136)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1250)
at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:517)
at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:467)
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:50)
at com.google.apphosting.runtime.jetty.AppVersionHandlerMap.createHandler(AppVersionHandlerMap.java:219)
at com.google.apphosting.runtime.jetty.AppVersionHandlerMap.getHandler(AppVersionHandlerMap.java:194)
at com.google.apphosting.runtime.jetty.JettyServletEngineAdapter.serviceRequest(JettyServletEngineAdapter.java:134)
at com.google.apphosting.runtime.JavaRuntime$RequestRunnable.run(JavaRuntime.java:446)
at com.google.tracing.TraceContext$TraceContextRunnable.runInContext(TraceContext.java:435)
at com.google.tracing.TraceContext$TraceContextRunnable$1.run(TraceContext.java:442)
at com.google.tracing.CurrentContext.runInContext(CurrentContext.java:186)
at com.google.tracing.TraceContext$AbstractTraceContextCallback.runInInheritedContextNoUnref(TraceContext.java:306)
at com.google.tracing.TraceContext$AbstractTraceContextCallback.runInInheritedContext(TraceContext.java:298)
at com.google.tracing.TraceContext$TraceContextRunnable.run(TraceContext.java:439)
at com.google.apphosting.runtime.ThreadGroupPool$PoolEntry.run(ThreadGroupPool.java:251)
at java.lang.Thread.run(Thread.java:724)
Caused by: java.io.FileNotFoundException: class path resource [odk-settings.xml] cannot be opened because it does not exist
at org.springframework.core.io.ClassPathResource.getInputStream(ClassPathResource.java:157)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:328)
... 30 more
W2013-11-18 18:22:29.350
Failed startup of context com.google.apphosting.utils.jetty.RuntimeAppEngineWebAppContext@1675800{/,/base/data/home/apps/s~ideusreportes/1.371723784598766355}
... 30 more
W2013-11-18 18:22:29.351
Nested in org.springframework.beans.factory.BeanDefinitionStoreException: IOException parsing XML document from class path resource [odk-settings.xml]; nested exception is java.io.FileNotFoundException: class path resource [odk-settings.xml] cannot be opened because it does not exist:
C2013-11-18 18:22:29.356
Uncaught exception from servlet
javax.servlet.UnavailableException: Initialization failed.
at com.google.apphosting.runtime.jetty.AppVersionHandlerMap.createHandler(AppVersionHandlerMap.java:228)
I2013-11-18 18:22:29.360
This request caused a new process to be started for your application, and thus caused your application code to be loaded for the first time. This request may thus take longer and use more CPU than a typical request for your application.
> On Mon, Nov 18, 2013 at 2:42 AM, Julio Garcia Perez < julio...@ideusingenieros.com > wrote:
>> And the logs show this:
>> Is there any way to fix it?
>> Thanks!
>> "ODK Community" group.
>> For more options, visit https://groups.google.com/groups/opt_out.
> Mitch Sundt
> Software Engineer
> University of Washington
> mitche...@gmail.com
Try re-running the installer and re-uploading it to AppEngine. It looks
like the upload did not complete successfully.
After the upload completes, please copy everything out of the scrolling
window and save it. If your ODK Aggregate does not work after that
re-upload, then send me the file directly ( mitchellsundt@gmail.com ).
If it does work, there is no need to send me the upload log, as everything
worked as expected.
On Mon, Nov 18, 2013 at 10:03 AM, Julio Garcia Perez < juliogarcia@ideusingenieros.com> wrote:
... 30 more
... 30 more
I downloaded the ODK Aggregate v1.4 windows-installer.exe and the set up
went fine, but when I try to log in, i just get this screen
Groups "ODK Community" group.
