The Garmin Monterra looks like it might be a prime device for ODK
implementation (minus phone capabilities). Given that it has an Android OS,
GPS, and camera, is there any reason to suspect that it won't work with
ODK? Have any field-tests been conducted?
ODK Collect should run on any Android OS 1.6+ device. It will likely
work on the Monterra, but that all depends on what, if anything,
Garmin did to the operating system.
Need ODK services? http://nafundi.com provides form design,
professional support, custom reporting, and software development for
ODK.
GPS, and camera, is there any reason to suspect that it won't work with ODK?
Has anyone tried using the Garmin Monterra with ODK?
On Thursday, September 12, 2013 at 5:34:16 PM UTC-4, erbaugh.jt wrote:
> The Garmin Monterra looks like it might be a prime device for ODK implementation (minus phone capabilities). Given that it has an Android OS, GPS, and camera, is there any reason to suspect that it won't work with ODK? Have any field-tests been conducted?
> https://buy.garmin.com/en-US/US/on-the-trail/handhelds/monterra-/prod113522.html
> Cheers.
