Can I know where I can get a document showing the complete reserved words
and hoe to use it for the excel document that I can design for me to
generate a XForm with XLSForm platom.
I want to know :
If out of survey, choices and settings we have others valide sheets?
What is the complete and exhaustive list of columns for each sheet
listed on the point 1.
What is the sysax acceptable for each column
If this information is available in one specific source code, which one?
http://xlsform.org/
I want to know :
http://xlsform.org/#choices%20worksheet
http://xlsform.org/#survey%20worksheet
Best and Regards
Ronald Munjoma
Thanks a lot for your response, I already read the complete tutorial and
use the knowledge in the document to develop with survey, but I want to
know if this is ALL, I van get, because it can be just part of what you can
put in your survey.
Stanyslas Matayo
Le lundi 15 décembre 2014 19:16:50 UTC+2, Ronald Munjoma a écrit :
> HI,
> On 15 December 2014 at 18:02, Stanyslas Matayo <matay...@gmail.com > wrote:
>> Dears,
> http://xlsform.org/
>> I want to know :
>> 1. If out of survey, choices and settings we have others valide sheets?
>> 2. What is the complete and exhaustive list of columns for each sheet
> Best and Regards
> Ronald Munjoma
>> 3. What is the sysax acceptable for each column
>> Thanks in advance
>> Stanyslas Matayo
>> "ODK Developers" group.
>> email to opendatakit-developers+unsubscribe@googlegroups.com
> Best and Regards
> Ronald Munjoma
> +263 775 625 283, +263 776 444 309
As with any active effort, there are ongoing changes and revisions, and the
documentation tends to lag behind those.
The ODK team and the other groups are trying to consolidate all the
documentation onto xlsform.org or have it linked from that site. However,
some of the documentation currently on the opendatakit.org site, and on the
group lists (and on other groups' sites) may or may not contain additional
insights or information. Furthermore, different groups have extended ODK
in different ways, and they will have divergent sets of features.
New features are also being added to the XForms engine (Javarosa) that
interprets the forms generated by XLSForm. In particular, new functions are
not likely to be promptly documented on xlsform.org.
New widgets and appearances are slowly being added to ODK Collect, and
documentation for those will also take longer to appear on that site.
On Mon, Dec 15, 2014 at 9:28 AM, Stanyslas Matayo wrote:
> Dear Ronald,
> put in your survey.
> Thanks
> Stanyslas Matayo
>> HI,
>>> Dears,
>>> words and hoe to use it for the excel document that I can design for me to
>> http://xlsform.org/
>>> I want to know :
>> Best and Regards
>> Ronald Munjoma
>>> Thanks in advance
>>> Stanyslas Matayo
>>> Groups "ODK Developers" group.
>>> an email to opendatakit-developers+unsubscribe@googlegroups.com.
>> Best and Regards
>> Ronald Munjoma
