I would like to get data in a repeat based on the choices selected before the repeat group. I can do this for the name of the Animal but would also like the ID, Location and Sex to appear as notes.
I have attached a minimal version
I’ve tried multiple ways of tackling this, none have worked.
and you need to add true() to choice_filter column of your select_multiple question.
This would be something like: Test (1).xlsx (9.4 KB)
You can find a similar example in https://docs.getodk.org/form-logic/#id27
