you might benefit from our ODK compatible form designer, the KoBo Form
Designer http://www.peacebuildingdata.org/kfb/KoBoFormDesigner.html which
allows easy construction of complex skip logic. It will allow you to add
skip logic to multiple questions at once, and you can copy-paste questions
to duplicate them in the graphical form tree. It also has a beta-feature,
cascading selection from itemsets.
we don't support gotos. we do have a notion of repeating, but that's
to create more prompts inside the loop. there is no easy way to have
an exit condition based on an answer.
could you describe more about what these prompts would be? we might be
able to figure out a different approach.
yaw
On Mon, Sep 19, 2011 at 23:13, Sanjeev Swamy wrote:
> I am currently working on a survey that requires that after a certain
> condition, we go back to a previous question.
> For example, say you have:
> Q1
> Q2
> If Q2 = Y; goto Q1
> Q3
> When Q2= Y then it goes back to asking Q1 and Q2. It breaks out of
> this loop only when Q2 = N.
> Would this be possible using ODK?
> Thank You,
> Sanjeev
I think I'm just going to create duplicate variables asking the same
question, instead.
For example,
Q1
Q2
If Q2 = Y then (..going back to Q1)
Q1_duplicate
Q2_duplicate
if Q2_duplicate = Y then
Q1_duplicate2
Q2_duplicate2
Q3
Please let me know if there is a better approach I can take.
Sanjeev
On Sep 20, 11:07 am, Yaw Anokwa wrote:
> hi sanjeev,
> yaw
> > Q1
> > Q2
> > If Q2 = Y; goto Q1
> > Q3
> > Thank You,
> > Sanjeev
On Tue, Sep 20, 2011 at 18:38, Sanjeev Swamy wrote:
> hi Yaw,
> question, instead.
> For example,
> Q1
> Q2
> Q1_duplicate
> Q2_duplicate
> Q1_duplicate2
> Q2_duplicate2
> Q3
> Thanks,
> Sanjeev
>> hi sanjeev,
>> yaw
>> > Q1
>> > Q2
>> > If Q2 = Y; goto Q1
>> > Q3
>> > Thank You,
>> > Sanjeev
