GPS question in ODK-Clinic
Hi everyone,
I am trying to set up a form for field workers using ODK-Clinic. How do I add a GPS question in OpenMRS?. I can add the question in the xform manually, but I am not sure what data type should I use in OMRS.
Thanks in advance
William
Hi William, if your "xforms.saveFormat" global property has a value of
javarosa,
While, in the form designer, just set the data type to GPS
··· On Fri, Mar 9, 2012 at 6:04 PM, William Aviles Monterrey wrote:
Hi everyone,
Thanks in advance
William
If we keep uppermost in our minds the unkind and unjust acts of others, we
shall find it impossible to love them as Christ has loved us; but if our
thoughts dwell upon the wondrous love and pity of Christ for us, the same
spirit will flow out to others.
Hi Daniel, thanks for your quick response.
I have the save format set to javarosa. I can put in the form designer GPS for the question, but what datatype should the concept be? String?
Best
William
··· From: Daniel Kayiwa Sent: Friday, March 09, 2012 9:09 AM To: opendatakit@googlegroups.com Subject: Re: [ODK Community] GPS question in ODK-Clinic
Hi William, if your "xforms.saveFormat" global property has a value of javarosa,
On Fri, Mar 9, 2012 at 6:04 PM, William Aviles Monterrey wravmon@yahoo.com wrote:
Hi everyone,
Thanks in advance
William
If we keep uppermost in our minds the unkind and unjust acts of others, we shall find it impossible to love them as Christ has loved us; but if our thoughts dwell upon the wondrous love and pity of Christ for us, the same spirit will flow out to others.
Concept data type should be TEXT
Best
William
javarosa,
On Fri, Mar 9, 2012 at 6:04 PM, William Aviles Monterrey < wravmon@yahoo.com> wrote:
Hi everyone,
Thanks in advance
William
Thank you Daniel
I really appreciate it
William
··· From: Daniel Kayiwa Sent: Friday, March 09, 2012 9:17 AM To: opendatakit@googlegroups.com Subject: Re: [ODK Community] GPS question in ODK-Clinic
On Fri, Mar 9, 2012 at 6:15 PM, William Aviles Monterrey wravmon@gmail.com wrote:
Best
William
Hi everyone,
Thanks in advance
William
