I have multiple questions on one screen
Question 1 has select_one option
Question 2 has select_one option - list populated based on Q1 above.
Question 3 has select_one option - list populated based on Q2 above.
Currently, I have to swipe screen forward and back to see the list in Q2 & Q3.
Is there a way to refresh the screen when a choice is picked using auto-refresh? The survey is long and ideally would like to present enumerators with multiple questions in one screen.
Any help is greatly appreciated.
Pramod.
No. This is a limitation in ODK Collect. If you have one question that is
dependent upon the value of another, like these select_one statements, they
need to be on separate screens.
Q3.
Pramod.
Thank you for your response.
Pramod.
On Tuesday, July 30, 2013 12:38:54 PM UTC-4, Mitch Sundt wrote:
> No. This is a limitation in ODK Collect. If you have one question that is dependent upon the value of another, like these select_one statements, they need to be on separate screens.
> Thanks
> Pramod.
> Post: opend...@googlegroups.com
> Unsubscribe: opendatakit...@googlegroups.com
> To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit...@googlegroups.com.
> Mitch Sundt
> Software Engineer
> mitche...@gmail.com
Pramod.
Pramod.
mitche...@gmail.com
Dear Mitch,
Is there any ways to do it, right now? I hope you can response this question, because i want my survey to be on one screen and the question is relevant with each other.
Regards,
On Wednesday, July 31, 2013 12:25:56 AM UTC+7, pmudd...@poverty-action.org wrote:
Bunhann,
No. It's still a limitation. ODK Survey might make some of these use
cases easier.
Pramod.
Pramod.
mitche...@gmail.com
Dear Mitch,
Regards,
Yaw is correct. ODK Survey does support this, but ODK Collect does not.
On Thu, May 8, 2014 at 7:42 AM, Yaw Anokwa wrote:
Bunhann,
cases easier.
Pramod.
Q2 & Q3.
Pramod.
mitche...@gmail.com
Dear Mitch,
Regards,
Bunhann,
cases easier.
Pramod.
Pramod.
mitche...@gmail.com
Dear Mitch,
Regards,
mitche...@gmail.com
Dear Yaw and Mitch,
Thank you for your respond. I think i have to find the way to solve this because I use ODK Collect on tablet, so it is not user interface friendly when i put in the sequence screen.
Regards
Pramod,
Enketo Smart Paper will allow you to do this if that meets your other
requirements. Hope that helps.
Cheers,
Martijn
> > Bunhann,
> > cases easier.
> > Yaw
> > >> Pramod.
> above.
> above.
> in Q2 & Q3.
> > >> > Thanks
> > >> > Pramod.
> > >> > Mitch Sundt
> > >> > Software Engineer
> > >> > mitche...@gmail.com
> > > Dear Mitch,
> > > Regards,
> > > For more options, visit https://groups.google.com/d/optout.
> > Mitch Sundt
> > Software Engineer
> > mitche...@gmail.com
> Dear Yaw and Mitch,
> Regards
