They entered my mind and changed the ID of my project and I can not access my data.
As I can get my project id . as this change ?
Nao sei o que aconteceu, minha nuvem tinha uma direçao
desarollo-paraguay.appspot.com, hoje de manha... agora a tarde tinha sido
trocada por paraguay-desarrollo.appspot.com! Acho que minha conta foi
hackeada... nao sei
E o ID do projeto tambem foi trocado.
Como pode acontecer isso?
El lunes, 17 de agosto de 2015, 14:13:41 (UTC-4), Fabio Medeiros escribió: > > They entered my mind and changed the ID of my project and I can not access my data. > As I can get my project id . as this change ? > >Eu tenho dados guardados na direçao desarrollo-paraguay.appspot.com
e essa outra direçao nao aparece nada.
El lunes, 17 de agosto de 2015, 14:13:41 (UTC-4), Fabio Medeiros escribió: > > They entered my mind and changed the ID of my project and I can not access my data. > As I can get my project id . as this change ? > >Fabio,
Not sure I understand the question. Post it in your native language.
-- Need ODK services? http://nafundi.com provides form design, server setup, professional support, and software development for ODK.On Mon, Aug 17, 2015 at 1:13 PM, Fabio Medeiros ecieccrpodk@gmail.com wrote:
my data.
As I can get my project id . as this change ?--
The most likely cause is that you have 2 or more gmail accounts, and
AppEngine thinks you are in an account that you don't remember using.
In your browser, go to GMail, and sign out of it (logging you out of all
your accounts).
Then, log into the GMail account you believe has your appengine instance.
And go to either https://appengine.google.com
Or the new site: https://console.developers.google.com/project
Do you see the application id there?
If not, go back to GMail, sign out, and then sign in with your other gmail
account. Repeat.
These websites occasionally get confused when you are simultaneously logged
into 2 or more GMail accounts. Make sure you are logged into only one
account as you verify and search for your application.
On Mon, Aug 17, 2015 at 11:46 AM, Fabio Medeiros wrote:Eu tenho dados guardados na direçao desarrollo-paraguay.appspot.com
Boa noite, meu problema é recuperar o id do meu projeto, esse id foi trocado.
Tenho dados na direção que foi trocada.
Como eu posso restabelecer a minha direção?
A minha direção era desarrollo-paraguay.appspot.com e agora aparece paraguay-desarrollo.appspot.com.
I do not understand. There is an ODK Aggregate running on
http://desarrollo-paraguay.appspot.com/
If ODK Collect is contacting the wrong server, go to the configuration
setting under General Settings / Server Settings / Configure platform
Settings to change the server URL.
NOTE: you should revoke "Form Manager" privileges from the anonymous user
if this contains meaningful data. If the data contains sensitive
information, you should revoke all privileges from the anonymous user and
specify a username in ODK Collect with Data Collector permissions (and use
that for data submissions).
On Mon, Aug 17, 2015 at 6:15 PM, Fabio Medeiros wrote:Boa noite, meu problema é recuperar o id do meu projeto, esse id foi
trocado.
Como eu posso restabelecer a minha direção?A minha direção era desarrollo-paraguay.appspot.com e agora aparece
paraguay-desarrollo.appspot.com.--
