Hi, I installed Aggregate on Ubuntu 14.04 Desktop but I have the Error 503
"The application is not currently available". I did the following steps:
1.I have LAMP already installed, and phpmyadmin
2. Install Java
java -version
java version "1.6.0_31"
OpenJDK Runtime Environment (IcedTea6 1.13.3) (6b31-1.13.3-1ubuntu1)
OpenJDK 64-Bit Server VM (build 23.25-b01, mixed mode)
3. Install Tomcat 6, it is working view the first attache
4. Run ODK Aggregate v1.4.3 linux-x64-installer.rum following the default
config and ports
5. Run the create_db_and_user.sql script (I verified that the data base
was created)
6. I copy the ODKAggregate.war to /var/lib/tomcat6/webapps
ls -al
total 58752
drwxrwxr-x 4 tomcat6 tomcat6 4096 jun 3 20:04 .
drwxr-xr-x 6 root root 4096 may 26 18:32 ..
drwxr-xr-x 9 tomcat6 tomcat6 4096 jun 3 20:04 ODKAggregate
-rw-r--r-- 1 root root 60140255 jun 3 20:04 ODKAggregate.war
drwxr-xr-x 3 root root 4096 may 26 18:32 ROOT
7. http://localhost:8080/ODKAggegate or http://172.31.1.103/ODKAggregate
has the same error message view the second attache.
Please advice.
Per the instructions at
http://opendatakit.org/use/aggregate/tomcat-install/, Aggregate 1.4
requires Java 7. Looks like you are running Java 6.
You can confirm this the issue by going into your Tomcat logs. There
will probably be a message about unsupported major.minor version 51.
2. Install Java
java -version
config and ports
5. Run the create_db_and_user.sql script (I verified that the data base was
created)
ls -al
total 58752
Please advice.
run tomcat manager-gui and add war to it by using browse. hope this will work
On Wednesday, June 4, 2014 at 5:36:31 AM UTC+5, odkte...@gmail.com wrote:
> Hi, I installed Aggregate on Ubuntu 14.04 Desktop but I have the Error 503 "The application is not currently available". I did the following steps:
> 2. Install Java
> # java -version
> 4. Run ODK Aggregate v1.4.3 linux-x64-installer.rum following the default config and ports
> 5. Run the create_db_and_user.sql script (I verified that the data base was created)
> # ls -al
> total 58752
> 7. http://localhost:8080/ODKAggegate or http://172.31.1.103/ODKAggregate has the same error message view the second attache.
> Please advice.
> Thanks
