Help installing odk aggregate
Hi. Can you help, please.
When the ODK Aggregate installer gets to running the script, it goes:
Looking for java...
Using JAVA_HOME and updating PATH
---END-SCRIPT-FAILURE---
Its a windows 7 service pack 1 64 bit logged in as administrator
Java version 7 update 75 build 1.7.0_75-b13 (64 bit)
ODK Aggregate v1.4.5
Thanks!
p.s. I posted this a couple of hours ago ... I thought it was to here, but
now I can't find it. Apologies if I've posted twice.
create JRE_HOME at CONTROL PANEL >> ADVANCED SYSTEM SETTING >> ENVIRONMENT VARIABLE >> USER VARIABLE >> NEW >> Variable name "JRE_HOME" >> Variable value "C:\Program Files\Java\jre1.7"
Maybe it help you
regards
··· On Sunday, March 15, 2015 at 2:12:44 PM UTC+7, Richard Moriarty wrote: > Hi. Can you help, please. > When the ODK Aggregate installer gets to running the script, it goes: > > Looking for java... > Using JAVA_HOME and updating PATH > ---END-SCRIPT-FAILURE--- > > Its a windows 7 service pack 1 64 bit logged in as administrator > Java version 7 update 75 build 1.7.0_75-b13 (64 bit) > ODK Aggregate v1.4.5 > > Thanks! > p.s. I posted this a couple of hours ago ... I thought it was to here, but now I can't find it. Apologies if I've posted twice.
i.e., there is something wrong with your java install.
There are many ways that this can get messed up. While it is not necessary
when things are working correctly, a good goal when you do have a bad java
install is:
When you open a cmd window (Start Menu - search for 'cmd' in the programs
and files, and launch that -- it opens a cmd window).
Type:
java -version
at the prompt.
If you have a good java install, it should display the java version:
e.g.:
C:\Users\Administrator\Downloads>java -version
java version "1.7.0_71"
Java(TM) SE Runtime Environment (build 1.7.0_71-b14)
Java HotSpot(TM) 64-Bit Server VM (build 24.71-b01, mixed mode)
··· ------------ I recommend going to your Control Panel / Programs and Features and uninstalling all of your Java versions.
Then open the cmd window and see if it is finding a java program.
And search the web for how to remove java.
Then re-installing just the Java 7 JRE or JDK. Then see if the version is
displayed correctly in the cmd window.
Looking for java...
Thanks!
Maybe it help you
regards
Thank you both.
Ok I will persist with getting an uninstall to work. No luck so far. Tried
on the mac too :slight_smile:
On Windows, after uninstall, looking to see it's all gone, and reinstall,
JAVA_HOME says jre1.8. But I am running the 1.7 installer.
I have to leave this for a day or so.
Thanks for your help.
install is:
Type:
java -version
at the prompt.
e.g.:
Looking for java...
Thanks!
Maybe it help you
regards
https://groups.google.com/d/topic/opendatakit/h12r15U9Rcc/unsubscribe.
