Help me to find the PROBLEM - I installed ODK Collect v1.3 on my Android 2.3.5 - if i open odk app my mobile always Restarting What will i do for that
that.
    If I install other versions on my mobile it will show that
removeSD: card : error like that.
help me to find this problem
Please file two reports (one for the restart issue, another for the SD
card issue) at http://code.google.com/p/opendatakit/issues/list.
Describe the phone (make/model) that you are using, the versions of
ODK Collect you are using, the exact steps you are taking, and the
exact error message or result. The more detail you can provide, the
more likely the core team will be able to fix your problem.
ยทยทยท -- Need ODK help? Go to http://nafundi.com for custom features, form design, implementation support, and user training for ODK.
that.
    If I install other versions on my mobile it will show that removeSD:
"ODK Developers" group.
