hello I made this form and I searched the forum for an answer for repeated values and it works fine for me but now I want to add a begin repeat I couldn't make it work can someone help me modify it or understand the levels ../
this is the formula that works it has begin repeat ESCANEO and begin_group Escaneo and looks for the value in ESCAN2
not(selected(join(' ',/mega2.0fila_mensaje/ESCANEO[./Escaneo2/ESCAN2=current()/../ESCAN2 and position(.) != position(current()/../..)]/Escaneo2/ESCAN2),.))
The formula I want to do is image 2 I added a begin repeat inicio
not(selected(join(' ',/mega2.0fila_grupo_forum/inicio/ESCANEO[./Escaneo2/ESCAN2=current()/../../ESCAN2 and position(.) != position(current()/../../..)]/ESCANEOEscaneo2/ESCAN2),.)))
It looks like you are trying to avoid duplicates across repeat instances. When you add the outer repeat inicio
, do you want to prevent duplicate values for ESCAN2
just within the current inicio
instance or across all instances of inicio
Can you please share your XLSForm?
I would like to scan many codes "inicio" it allows me to decide how many at a time I will scan I would like everything that is scanned in ${SCAN2} only to be scanned 1 time in all repetitions I achieved it when I had a begin repeat only and begin group now that add inicio I can't find how to express it anymore.thanks for your time
forum.zip (277.5 KB)
