I need to know if we may edit the xls form that has contains results[output]
**What ODK tool and version are you using? And on what device and operating system version?**latest version
i have tried to save in storage/odk/ but i can't see it.
only this issue of editing the results after been submitted into server
Not quite clear about your query. However, if I got it right, yes you can make minor changes to the data collection form and upload that to you Aggregate. Just change the version and if you you add another field or so you need to collect data separately under new form.
And just to add to @A.N.M_AL-IMRAN's response, https://docs.opendatakit.org/form-update/ has more on how to update forms!
Yea!!, I tried to use the device used in the data collection process to add the forms which had mistakes and off course they might open and refill again, though all data collected must be cleared/reinstall then use the forms.. It works
